Aller au contenu principal
Hover-1 Charger Bluetooth Speaker Replacement
Ce dont vous avez besoin
  1. Hover-1 Charger Bluetooth Speaker Replacement, Unplugging the Battery: étape 1, image 1 de 2 Hover-1 Charger Bluetooth Speaker Replacement, Unplugging the Battery: étape 1, image 2 de 2
    • Flip the hoverboard over so that the warning label is facing up.
    • Remove the twelve 12 mm screws with a Phillips #2 screwdriver.
    • Remove the four 10 mm screws with a Phillips #2 screwdriver.
    • The screws nearest to the wheels may be hard to access. Be sure to use a long, thin screwdriver.
  2. Hover-1 Charger Bluetooth Speaker Replacement: étape 2, image 1 de 1
    • Pull the right cover away from the hoverboard to expose the battery.
  3. Hover-1 Charger Bluetooth Speaker Replacement: étape 3, image 1 de 2 Hover-1 Charger Bluetooth Speaker Replacement: étape 3, image 2 de 2
    • Disconnect the two pronged black and yellow cable.
  4. Hover-1 Charger Bluetooth Speaker Replacement: étape 4, image 1 de 1
    • Pull the left cover away from the hoverboard.
  5. Hover-1 Charger Bluetooth Speaker Replacement: étape 5, image 1 de 2 Hover-1 Charger Bluetooth Speaker Replacement: étape 5, image 2 de 2
    • Disconnect the two pronged black and yellow cable. The battery is now fully disconnected.
  6. Hover-1 Charger Bluetooth Speaker Replacement, Bluetooth Speaker: étape 6, image 1 de 1
    • Locate the speaker attached to the left cover of the hoverboard.
  7. Hover-1 Charger Bluetooth Speaker Replacement: étape 7, image 1 de 2 Hover-1 Charger Bluetooth Speaker Replacement: étape 7, image 2 de 2
    • Unplug the red and white four pin connector from the circuit board. Unplugging this connector is photographed as an example.
    • Unplug the white and blue three pin connector from the circuit board.
    • Unplug the white and blue two pin connector from the circuit board.
  8. Hover-1 Charger Bluetooth Speaker Replacement: étape 8, image 1 de 2 Hover-1 Charger Bluetooth Speaker Replacement: étape 8, image 2 de 2
    • Using a Phillips #1 screwdriver, remove the two 7 mm screws from the circuit board.
  9. Hover-1 Charger Bluetooth Speaker Replacement: étape 9, image 1 de 2 Hover-1 Charger Bluetooth Speaker Replacement: étape 9, image 2 de 2
    • Using a Phillips #1 screwdriver, remove the three screws securing the speaker to the outer shell.
  10. Hover-1 Charger Bluetooth Speaker Replacement: étape 10, image 1 de 1
    • Remove the speaker and circuit board from the outer shell.
Bryson Shishido
Membre depuis le 10/10/19
145 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team S12-G1, Regan Fall 2019 Membre de l'équipe Cal Poly, Team S12-G1, Regan Fall 2019
CPSU-REGAN-F19S12G1
4 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 34
Total : 1,332
