Aller au contenu principal
Hover-1 Charger Gyroscope Sensor Board Replacement
Ce dont vous avez besoin
  1. Hover-1 Charger Gyroscope Sensor Board Replacement, Unplugging the Battery: étape 1, image 1 de 2 Hover-1 Charger Gyroscope Sensor Board Replacement, Unplugging the Battery: étape 1, image 2 de 2
    • Flip the hoverboard over so that the warning label is facing up.
    • Remove the twelve 12 mm screws with a Phillips #2 screwdriver.
    • Remove the four 10 mm screws with a Phillips #2 screwdriver.
    • The screws nearest to the wheels may be hard to access. Be sure to use a long, thin screwdriver.
  2. Hover-1 Charger Gyroscope Sensor Board Replacement: étape 2, image 1 de 1
    • Pull the right cover away from the hoverboard to expose the battery.
  3. Hover-1 Charger Gyroscope Sensor Board Replacement: étape 3, image 1 de 2 Hover-1 Charger Gyroscope Sensor Board Replacement: étape 3, image 2 de 2
    • Disconnect the two pronged black and yellow cable.
  4. Hover-1 Charger Gyroscope Sensor Board Replacement: étape 4, image 1 de 1
    • Pull the left cover away from the hoverboard.
  5. Hover-1 Charger Gyroscope Sensor Board Replacement: étape 5, image 1 de 2 Hover-1 Charger Gyroscope Sensor Board Replacement: étape 5, image 2 de 2
    • Disconnect the two pronged black and yellow cable. The battery is now fully disconnected.
  6. Hover-1 Charger Gyroscope Sensor Board Replacement, Gyroscope Sensor Board: étape 6, image 1 de 3 Hover-1 Charger Gyroscope Sensor Board Replacement, Gyroscope Sensor Board: étape 6, image 2 de 3 Hover-1 Charger Gyroscope Sensor Board Replacement, Gyroscope Sensor Board: étape 6, image 3 de 3
    • Unplug the white five pin connector from the gyroscope sensor board.
    • Unplug the red, yellow, blue, green, black and white six pin connector.
    • Unplug the black and red two pin connector.
    • Unplug the black, yellow, green and red four pin connector. Unplugging this connector is photographed as an example.
  7. Hover-1 Charger Gyroscope Sensor Board Replacement: étape 7, image 1 de 2 Hover-1 Charger Gyroscope Sensor Board Replacement: étape 7, image 2 de 2
    • Remove the four 10 mm screws from the gyroscope sensor board with a Phillips #2 screwdriver.
  8. Hover-1 Charger Gyroscope Sensor Board Replacement: étape 8, image 1 de 3 Hover-1 Charger Gyroscope Sensor Board Replacement: étape 8, image 2 de 3 Hover-1 Charger Gyroscope Sensor Board Replacement: étape 8, image 3 de 3
    • Push the rubber sheaths away from the clasp of the green bullet connector.
    • Grasp the connector at the metal junction and disconnect.
    • Repeat for the yellow and red bullet connectors.
    • There may be a zip tie holding these wires together. Cut this off.
    • These bullet connectors may be hard to disconnect; do not be afraid to pull with strong force.
  9. Hover-1 Charger Gyroscope Sensor Board Replacement: étape 9, image 1 de 1
    • Remove the gyroscope sensor board.
Melanie Hardell
Membre depuis le 10/10/19
505 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team S12-G1, Regan Fall 2019 Membre de l'équipe Cal Poly, Team S12-G1, Regan Fall 2019
CPSU-REGAN-F19S12G1
4 membres
6 tutoriels rédigés
4 commentaires
Hi Where can I find the replacement sensor board? Thanks!
Jason LaDuke - Réponse
where do i find the replacement sensor board?
one wheel of my board doesn’t work
Philip Donkoh - Réponse
I need one of these replacement gyros please how I get
Matthew Isaiah Cowart - Réponse
Worthless guide. No instructions on where to get the replacement gyro boards
Fuckaboi - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 24
30 derniers jours : 85
Total : 4,709
