Aller au contenu principal
Hover-1 Eagle LED Headlight Replacement
Ce dont vous avez besoin
  1. Hover-1 Eagle LED Headlight Replacement, LED Headlight: étape 1, image 1 de 3 Hover-1 Eagle LED Headlight Replacement, LED Headlight: étape 1, image 2 de 3 Hover-1 Eagle LED Headlight Replacement, LED Headlight: étape 1, image 3 de 3
    • Remove the four screws from the bottom side of the display housing using a Phillips #2 screwdriver.
  2. Hover-1 Eagle LED Headlight Replacement: étape 2, image 1 de 3 Hover-1 Eagle LED Headlight Replacement: étape 2, image 2 de 3 Hover-1 Eagle LED Headlight Replacement: étape 2, image 3 de 3
    • Carefully remove the top of the housing containing the display screen.
    • Remove the top of the housing slowly to avoid damaging the wires.
  3. Hover-1 Eagle LED Headlight Replacement: étape 3, image 1 de 2 Hover-1 Eagle LED Headlight Replacement: étape 3, image 2 de 2
    • Slide the LED light cover upwards out of the display housing
    • Be gentle when removing the LED light cover to avoid damaging the LED's connecting wires.
    • The LED circuit board should slide out with the LED light cover.
    • To reassemble, align the prongs of the LED cover with the holes in the LED circuit board.
  4. Hover-1 Eagle LED Headlight Replacement: étape 4, image 1 de 3 Hover-1 Eagle LED Headlight Replacement: étape 4, image 2 de 3 Hover-1 Eagle LED Headlight Replacement: étape 4, image 3 de 3
    • Using a soldering iron, desolder the black and red wires from the LED circuit board.
    • To reassemble, solder the same black and red wires onto the new LED circuit board.
4 autres ont terminé cette réparation.
Andrew Gaskell
Membre depuis le 01/23/20
1 008 Réputation
5 tutoriels rédigés
Équipe
Cal Poly, Team S1-G2, White Winter 2020 Membre de l'équipe Cal Poly, Team S1-G2, White Winter 2020
CPSU-WHITE-W20S1G2
4 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 10
Total : 1,033
