Aller au contenu principal
Hover-1 Eagle Throttle/Brake Lever Replacement
Ce dont vous avez besoin
  1. Hover-1 Eagle Throttle/Brake Lever Replacement, Throttle/Brake Lever: étape 1, image 1 de 3 Hover-1 Eagle Throttle/Brake Lever Replacement, Throttle/Brake Lever: étape 1, image 2 de 3 Hover-1 Eagle Throttle/Brake Lever Replacement, Throttle/Brake Lever: étape 1, image 3 de 3
    • Unscrew the scooter handle.
    • The scooter handles are left-handed or reverse threaded, so twist clockwise to remove them.
  2. Hover-1 Eagle Throttle/Brake Lever Replacement: étape 2, image 1 de 3 Hover-1 Eagle Throttle/Brake Lever Replacement: étape 2, image 2 de 3 Hover-1 Eagle Throttle/Brake Lever Replacement: étape 2, image 3 de 3
    • Push back the fastening clips by wedging the plastic spudger between the clip and the throttle handle.
    • Insert iFixit opening picks between each fastening clip and the throttle handle to prevent re-fastening.
    • Pull the throttle lever off gently by pulling towards you.
    • The spring housed in the handle can sometimes send the lever flying. Maintain a firm grip on the throttle lever.
  3. Hover-1 Eagle Throttle/Brake Lever Replacement: étape 3, image 1 de 3 Hover-1 Eagle Throttle/Brake Lever Replacement: étape 3, image 2 de 3 Hover-1 Eagle Throttle/Brake Lever Replacement: étape 3, image 3 de 3
    • To reassemble, insert the spring into the placement hole, housed inside the throttle handle. Insert the other end of the spring into the placement hole inside the throttle body housing.
  4. Hover-1 Eagle Throttle/Brake Lever Replacement: étape 4, image 1 de 3 Hover-1 Eagle Throttle/Brake Lever Replacement: étape 4, image 2 de 3 Hover-1 Eagle Throttle/Brake Lever Replacement: étape 4, image 3 de 3
    • Twist the throttle lever back to its original orientation by rotating it to the left.
    • Apply pressure to the throttle handle until you hear the fastening clips take hold the of the throttle lever.
    • Make sure the throttle lever is fully inserted and flush with the display throttle body.
  5. Hover-1 Eagle Throttle/Brake Lever Replacement: étape 5, image 1 de 3 Hover-1 Eagle Throttle/Brake Lever Replacement: étape 5, image 2 de 3 Hover-1 Eagle Throttle/Brake Lever Replacement: étape 5, image 3 de 3
    • Reattach the scooter handle.
    • Make sure to twist the handles counterclockwise to tighten.
Ligne d'arrivée
4 autres ont terminé cette réparation.
Andrew Gaskell
Membre depuis le 01/23/20
1 008 Réputation
5 tutoriels rédigés
Équipe
Cal Poly, Team S1-G2, White Winter 2020 Membre de l'équipe Cal Poly, Team S1-G2, White Winter 2020
CPSU-WHITE-W20S1G2
4 membres
6 tutoriels rédigés
24 commentaires
Great detail……….. Where can I buy the replacement part (throttle) the company hover1 isn't answering me and they don't have this part on their website. Thanks
hanjna76 - Réponse
Im needed a throttle did anyone have any luck?
rodarte_amanda1992 -
Where do I buy the part where do I get it please let me know The brake lever
poorbubbaa - Réponse
Necesito acelerador y no lo encuentro.
Josue Villanueva - Réponse
I cant squeeze the spudger and the pick between this and the spudger broke…what the!!!
Cheri Rael - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 10
7 derniers jours : 32
30 derniers jours : 84
Total : 15,452
