Aller au contenu principal
How to Activate 12 V Aux Power in a 2007-2014 Chevrolet Suburban
Ce dont vous avez besoin
  1. How to Activate 12 V Aux Power in a 2007-2014 Chevrolet Suburban, How to Activate 12 V Aux Power in a 2007-2014 Chevrolet Suburban: étape 1, image 1 de 1
    • Locate the wiring harness bundle, which exits the firewall underneath the brake booster.
  2. How to Activate 12 V Aux Power in a 2007-2014 Chevrolet Suburban: étape 2, image 1 de 1
    • Identify the auxiliary wire, which is folded and taped to either the wiring harness or the fire wall.
  3. How to Activate 12 V Aux Power in a 2007-2014 Chevrolet Suburban: étape 3, image 1 de 1
    • Use a knife to cut the tape away from the wire and unravel it.
  4. How to Activate 12 V Aux Power in a 2007-2014 Chevrolet Suburban: étape 4, image 1 de 1
    • Run the wire against the battery box.
  5. How to Activate 12 V Aux Power in a 2007-2014 Chevrolet Suburban: étape 5, image 1 de 3 How to Activate 12 V Aux Power in a 2007-2014 Chevrolet Suburban: étape 5, image 2 de 3 How to Activate 12 V Aux Power in a 2007-2014 Chevrolet Suburban: étape 5, image 3 de 3
    • Place the ring terminal (washer end) of the wire on the right post located at the front of the battery.
    • Place the 10 mm washer on the post.
    • Tighten the washer using a 10 mm wrench, crescent wrench, or pliers.
    • Post size and location may vary slightly in different models. The washer will fit snuggly around the correct post.
  6. How to Activate 12 V Aux Power in a 2007-2014 Chevrolet Suburban: étape 6, image 1 de 1
    • After hooking up the wire, check to make sure the 40 amp fuse is installed for the auxiliary pin.
    • If the fuse is not installed, there will be an empty space. This fuse can be purchased at any automotive shop.
Ligne d'arrivée
13 autres ont terminé cette réparation.
Lauryn Johnson
Membre depuis le 01/19/16
454 Réputation
1 tutoriel rédigé
Équipe
Oakland University, Team 6-14, Walwema Winter 2016 Membre de l'équipe Oakland University, Team 6-14, Walwema Winter 2016
OAK-WALWEMA-W16S6G14
1 membre
1 tutoriel rédigé
6 commentaires
This sends constant power to the trailer. What if I wanted to make that power switched by the ignition so when the key is off I can be confident that the trailer won't kill my truck battery? I know I can just unplug the trailer harness or pull this fuse to stop it, but That might be easy to forget to do.
Eric Wonderlich Jr. - Réponse
Eric, did you ever get an answer to your inquiry about killing the power to the trailer when the key is in the off position?
Bobby Burke -
It’s not a break booster, it is a brake booster. If you are going to be an author, you should know the meaning of the words you use.
Albert - Réponse
Never fails some troll somewhere..
Garry Foster -
“Words have meaning” geez Cyber Warrior. Tough talk from a distance. ?
nshourds -
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 10
7 derniers jours : 28
30 derniers jours : 166
Total : 34,020
