Aller au contenu principal
How to Check a Car's Tire Pressure
Ce dont vous avez besoin
  1. How to Check a Car's Tire Pressure, How to Check a Car's Tire Pressure: étape 1, image 1 de 2 How to Check a Car's Tire Pressure, How to Check a Car's Tire Pressure: étape 1, image 2 de 2
    • Your car's tire pressure information is likely located inside the car door frame toward the bottom.
    • You can also look up this information in your vehicle's owner's manual.
    • Do not refer to the tire pressure information printed on the tire itself! This displays the maximum tire pressure allowed, rather than the recommended amount.
  2. How to Check a Car's Tire Pressure: étape 2, image 1 de 3 How to Check a Car's Tire Pressure: étape 2, image 2 de 3 How to Check a Car's Tire Pressure: étape 2, image 3 de 3
    • Each tire has a valve stem located on the outer part of the wheel that sticks out.
    • Remove the cap by unscrewing it counter-clockwise and set it off to the side.
    • The cap is very small, so be sure to keep track of it!
  3. How to Check a Car's Tire Pressure: étape 3, image 1 de 2 How to Check a Car's Tire Pressure: étape 3, image 2 de 2
    • Place the stem of the tire pressure gauge onto the tire's valve stem and push on it with a decent amount of force.
    • You'll hear a brief hissing noise as the valve stem quickly opens and closes. If the noise continues, you likely aren't pressing down hard enough.
    • After a second or two, remove the tire pressure gauge. Again, you'll hear a brief hissing noise.
  4. How to Check a Car's Tire Pressure: étape 4, image 1 de 2 How to Check a Car's Tire Pressure: étape 4, image 2 de 2
    • Check the gauge to see what the tire pressure is. If it's low, add air to the tire until the gauge reads the proper tire pressure.
    • To reset the gauge to zero, press down on the gauge's bleeder valve.
Ligne d'arrivée
2 autres ont terminé cette réparation.
Craig Lloyd
Membre depuis le 02/10/16
35 546 Réputation
82 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 14
30 derniers jours : 61
Total : 1,919
