Aller au contenu principal
How to Fix a Broken Temple Arm of Gaoye Blue Light Eyeglasses
Ce dont vous avez besoin
  1. How to Fix a Broken Temple Arm of Gaoye Blue Light Eyeglasses, How to Fix a Broken Temple Arm of Gaoye Blue Light Eyeglasses: étape 1, image 1 de 3 How to Fix a Broken Temple Arm of Gaoye Blue Light Eyeglasses, How to Fix a Broken Temple Arm of Gaoye Blue Light Eyeglasses: étape 1, image 2 de 3 How to Fix a Broken Temple Arm of Gaoye Blue Light Eyeglasses, How to Fix a Broken Temple Arm of Gaoye Blue Light Eyeglasses: étape 1, image 3 de 3
    • Apply dish soap to the broken temple arm sections.
    • Scrub the broken temple arm sections with the dish soap for one minute.
  2. How to Fix a Broken Temple Arm of Gaoye Blue Light Eyeglasses: étape 2, image 1 de 3 How to Fix a Broken Temple Arm of Gaoye Blue Light Eyeglasses: étape 2, image 2 de 3 How to Fix a Broken Temple Arm of Gaoye Blue Light Eyeglasses: étape 2, image 3 de 3
    • Rinse the dish soap off of the temple arm sections with water.
    • Dry off the temple arm sections with a paper towel.
  3. How to Fix a Broken Temple Arm of Gaoye Blue Light Eyeglasses: étape 3, image 1 de 2 How to Fix a Broken Temple Arm of Gaoye Blue Light Eyeglasses: étape 3, image 2 de 2
  4. How to Fix a Broken Temple Arm of Gaoye Blue Light Eyeglasses: étape 4, image 1 de 3 How to Fix a Broken Temple Arm of Gaoye Blue Light Eyeglasses: étape 4, image 2 de 3 How to Fix a Broken Temple Arm of Gaoye Blue Light Eyeglasses: étape 4, image 3 de 3
    • Use the coated toothpick to apply a thin layer of Gorilla Super Glue to one of the broken temple arm sections.
    • Gorilla Super Glue works better when less of the product is applied. Make sure to only apply a thin layer of glue to the broken temple arm section.
  5. How to Fix a Broken Temple Arm of Gaoye Blue Light Eyeglasses: étape 5, image 1 de 2 How to Fix a Broken Temple Arm of Gaoye Blue Light Eyeglasses: étape 5, image 2 de 2
    • Press the two temple arm sections together and hold for one minute.
    • Caution: Gorilla Super Glue can remain on your skin for up to a week. Place hands away from the glue applied when holding the temple sections together to keep hands clean.
  6. How to Fix a Broken Temple Arm of Gaoye Blue Light Eyeglasses: étape 6, image 1 de 3 How to Fix a Broken Temple Arm of Gaoye Blue Light Eyeglasses: étape 6, image 2 de 3 How to Fix a Broken Temple Arm of Gaoye Blue Light Eyeglasses: étape 6, image 3 de 3
    • Tightly wrap masking tape around the area where you placed the temple arm sections together.
    • Leave the masking tape on for five minutes.
  7. How to Fix a Broken Temple Arm of Gaoye Blue Light Eyeglasses: étape 7, image 1 de 2 How to Fix a Broken Temple Arm of Gaoye Blue Light Eyeglasses: étape 7, image 2 de 2
    • Remove the masking tape.
  8. How to Fix a Broken Temple Arm of Gaoye Blue Light Eyeglasses: étape 8, image 1 de 3 How to Fix a Broken Temple Arm of Gaoye Blue Light Eyeglasses: étape 8, image 2 de 3 How to Fix a Broken Temple Arm of Gaoye Blue Light Eyeglasses: étape 8, image 3 de 3
    • Select a 1/4" heat-shrinking tube.
    • Slide the tube to the area where you applied the Gorilla Super Glue.
  9. How to Fix a Broken Temple Arm of Gaoye Blue Light Eyeglasses: étape 9, image 1 de 3 How to Fix a Broken Temple Arm of Gaoye Blue Light Eyeglasses: étape 9, image 2 de 3 How to Fix a Broken Temple Arm of Gaoye Blue Light Eyeglasses: étape 9, image 3 de 3
    • Plug in a handheld hair dryer.
    • Turn the handheld hair dryer to the highest heat setting.
  10. How to Fix a Broken Temple Arm of Gaoye Blue Light Eyeglasses: étape 10, image 1 de 3 How to Fix a Broken Temple Arm of Gaoye Blue Light Eyeglasses: étape 10, image 2 de 3 How to Fix a Broken Temple Arm of Gaoye Blue Light Eyeglasses: étape 10, image 3 de 3
    • Circulate the handheld hair dryer around the heat-shrinking tube until it is suctioned around the temple arm.
    • Caution: Keep your fingers away from the area you are aiming the hair dryer. The hair dryer produces high levels of heat that can irritate or burn a person's skin.
Ligne d'arrivée
Maia Michelle Brown
Membre depuis le 02/20/24
181 Réputation
1 tutoriel rédigé
Équipe
University of Arizona, Team 2-9, Cools Stephens Spring 2024 Membre de l'équipe University of Arizona, Team 2-9, Cools Stephens Spring 2024
ARIZONA-COOLS STEPHENS-S24S2G9
2 membres
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 5
7 derniers jours : 9
30 derniers jours : 33
Total : 111
