Introduction
In the process of disassembling and repairing electronic devices, you may need to remove dozens of screws with dozens of different uses.
If you are a Mobile Phone Repairer, a professional screw mat would be a best choice
The repair pad has a relatively high magnetic force, (as shown in the figure), which can effectively prevent small parts such as screws from sliding down, and a divided grid is used to store the screws or help you organize in any way you need.
If you can't remember how to reassemble, it's best to draw the same grid on a piece of paper and write out the type and steps of the screws.
If the amount of screws used in the dissembled are all the same size or just a few and easy to remember placement, then you don’t have to classify it, you can keep it safe.
Find a roll of wide tape and cut it into sections for the size and type of screw you need. Fold one side, fix it on the table, and then stick the screw on it.
You can also use paper (such as paper napkins), place different screws on the paper and wrap them in the paper, and write on them to mark them.
When reassembling your device, follow the instructions in reverse order.
24 autres ont terminé cette réparation.
Merci à ces traducteurs :
100%
Ces traducteurs nous aident réparer le monde ! Vous voulez contribuer ?
Commencez à traduire ›
