Aller au contenu principal
How to Open Your Logitech C920s Webcam
Ce dont vous avez besoin
  1. How to Open Your Logitech C920s Webcam, Prepare your webcam for disassembly: étape 1, image 1 de 3 How to Open Your Logitech C920s Webcam, Prepare your webcam for disassembly: étape 1, image 2 de 3 How to Open Your Logitech C920s Webcam, Prepare your webcam for disassembly: étape 1, image 3 de 3
    • Before you begin, unplug your webcam, close the mounting clip, and remove the privacy shutter.
  2. How to Open Your Logitech C920s Webcam, Remove the screw covers: étape 2, image 1 de 3 How to Open Your Logitech C920s Webcam, Remove the screw covers: étape 2, image 2 de 3 How to Open Your Logitech C920s Webcam, Remove the screw covers: étape 2, image 3 de 3
    • Be careful not to damage the rubber pads or plastic case during this step. Work slowly and don't push hard against the webcam.
    • Push an arm of a pair of angled tweezers under one of the rubber pads on the underside of the webcam.
    • There's a small hole near the center of the back edge (farthest from the lens). Try inserting your tweezers here to prevent damaging the pad.
    • Slide the tweezers farther under the pad and lift to remove it.
  3. How to Open Your Logitech C920s Webcam: étape 3, image 1 de 1
    • Repeat the previous step to remove the other pad.
  4. How to Open Your Logitech C920s Webcam, Remove the grille screws: étape 4, image 1 de 3 How to Open Your Logitech C920s Webcam, Remove the grille screws: étape 4, image 2 de 3 How to Open Your Logitech C920s Webcam, Remove the grille screws: étape 4, image 3 de 3
    • Use a Phillips screwdriver to remove the four 4.5 mm‑long screws securing the microphone grilles.
  5. How to Open Your Logitech C920s Webcam, Remove the microphone grilles: étape 5, image 1 de 3 How to Open Your Logitech C920s Webcam, Remove the microphone grilles: étape 5, image 2 de 3 How to Open Your Logitech C920s Webcam, Remove the microphone grilles: étape 5, image 3 de 3
    • Insert an opening tool in the microphone grille seam on the outer edge of the webcam.
    • Slide the opening tool along the seam to release the clips.
    • If you don't feel and hear the clips release, remove the opening tool and try again.
  6. How to Open Your Logitech C920s Webcam: étape 6, image 1 de 2 How to Open Your Logitech C920s Webcam: étape 6, image 2 de 2
    • Use your fingers to remove the microphone grille.
  7. How to Open Your Logitech C920s Webcam: étape 7, image 1 de 3 How to Open Your Logitech C920s Webcam: étape 7, image 2 de 3 How to Open Your Logitech C920s Webcam: étape 7, image 3 de 3
    • Repeat the process to remove the microphone grille on the other side.
    • During reassembly, put the grille covers in place and squeeze firmly to engage the clips.
  8. How to Open Your Logitech C920s Webcam, Remove the lens cover screws: étape 8, image 1 de 3 How to Open Your Logitech C920s Webcam, Remove the lens cover screws: étape 8, image 2 de 3 How to Open Your Logitech C920s Webcam, Remove the lens cover screws: étape 8, image 3 de 3
    • Use a Phillips screwdriver to remove the eight 8.0 mm‑long screws on the outer edges securing the lens cover.
  9. How to Open Your Logitech C920s Webcam, Remove the lens cover: étape 9, image 1 de 2 How to Open Your Logitech C920s Webcam, Remove the lens cover: étape 9, image 2 de 2
    • Use your fingers to lift and remove the lens cover.
  10. How to Open Your Logitech C920s Webcam, Fully open the hinges: étape 10, image 1 de 2 How to Open Your Logitech C920s Webcam, Fully open the hinges: étape 10, image 2 de 2
    • Tilt the main body of the webcam so its hinges are fully open.
  11. How to Open Your Logitech C920s Webcam, Remove the hinge screws: étape 11, image 1 de 2 How to Open Your Logitech C920s Webcam, Remove the hinge screws: étape 11, image 2 de 2
    • Use a Phillips screwdriver to remove the five screws securing the hinge mechanism:
    • Four 4.8 mm‑long screws
    • One 6.0 mm‑long screw
  12. How to Open Your Logitech C920s Webcam, Remove the mounting clip: étape 12, image 1 de 3 How to Open Your Logitech C920s Webcam, Remove the mounting clip: étape 12, image 2 de 3 How to Open Your Logitech C920s Webcam, Remove the mounting clip: étape 12, image 3 de 3
    • Tilt the mounting clip so the hinges lift away from the webcam.
    • Slide the hinges out of their recess and remove the mounting clip.
    • During reassembly, make sure both hinges are fully open before sliding them into place.
  13. How to Open Your Logitech C920s Webcam, Remove the rubber spacers: étape 13, image 1 de 3 How to Open Your Logitech C920s Webcam, Remove the rubber spacers: étape 13, image 2 de 3 How to Open Your Logitech C920s Webcam, Remove the rubber spacers: étape 13, image 3 de 3
    • Use tweezers or your fingers to remove the two circular rubber spacers from the outer edges of the webcam.
  14. How to Open Your Logitech C920s Webcam, Remove the inner housing: étape 14, image 1 de 3 How to Open Your Logitech C920s Webcam, Remove the inner housing: étape 14, image 2 de 3 How to Open Your Logitech C920s Webcam, Remove the inner housing: étape 14, image 3 de 3
    • Use an opening tool to gently pry up and unclip the left, right, and bottom edges of the plastic inner housing.
    • During reassembly, slide the housing into place and press gently around the perimeter to engage the clips.
  15. How to Open Your Logitech C920s Webcam: étape 15, image 1 de 2 How to Open Your Logitech C920s Webcam: étape 15, image 2 de 2
    • Remove the inner housing.
  16. How to Open Your Logitech C920s Webcam, Your webcam is open: étape 16, image 1 de 1
    • Your webcam is now open, with the internals accessible.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers Community for troubleshooting help.
Reuse or Recycle—Never put discarded electronic parts in household waste. Visit Logitech Recycling to find your nearest recycling points, including the option to mail back old devices to Logitech for free if there’s no convenient solution in your area. You can also take your e-waste to any R2 or e-Stewards certified recycler. And don’t let good working parts or repaired devices die a slow death in your sock drawer—pass them along to someone who can use them.
Share your experience—Leave a comment here or send your feedback directly to Logitech at repair@logitech.com to help shape future repair guides and product design.
Spencer Day
Membre depuis le 09/14/22
150 248 Réputation
995 tutoriels rédigés
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 7
30 derniers jours : 31
Total : 51
