Introduction
Use this guide to open a Logitech MX Ergo for cleaning or repair.
Ce dont vous avez besoin
Before you begin, flip the mouse's power switch into the OFF position.
Unplug all cables from your mouse.
Remove the magnetic cover by pulling it away from the bottom of your mouse.
Use a Torx T6 screwdriver to remove the six 5.7 mm-long screws securing the two halves of the mouse together.
Insert a spudger into the hole on the bottom of the mouse, beneath the trackball.
Use the spudger to push the trackball out of its recess.
Remove the trackball.
Insert the tip of an opening pick into the seam between the two halves, near the middle of the right edge.
Twist the opening pick to release the plastic clip.
Gently lift the top half and place it to the left of the mouse so you can access the internals.
Use the point of a spudger to gently lift alternating sides of the black sliding latch on the interconnect cable socket.
Lift the top half of the mouse straight up and remove it.
10 autres ont terminé cette réparation.
5 commentaires de tutoriel
Thank you. It was quite a coincidence that I found this because I had just purchased that fix it repair tool kit. It was pretty handy that I had it all right here in front of me. Thanks again you made it easy.
Hi @martilynn, thank you for sharing your experience! We're glad that the guide was useful for your repair.
Actually not necessary to remove the interconnect cable, and I wish I had not. Instructions do not include reassembly.
