Aller au contenu principal
How to Repair a Loose Rear Bicycle Wheel
Ce dont vous avez besoin
  1. How to Repair a Loose Rear Bicycle Wheel, How to Repair a Loose Rear Bicycle Wheel: étape 1, image 1 de 3 How to Repair a Loose Rear Bicycle Wheel, How to Repair a Loose Rear Bicycle Wheel: étape 1, image 2 de 3 How to Repair a Loose Rear Bicycle Wheel, How to Repair a Loose Rear Bicycle Wheel: étape 1, image 3 de 3
    • Loosen the rear axle.
    • Turn the bike around, and loosen the brake arm.
  2. How to Repair a Loose Rear Bicycle Wheel: étape 2, image 1 de 2 How to Repair a Loose Rear Bicycle Wheel: étape 2, image 2 de 2
    • Take the chain off the gear and take out the wheel.
  3. How to Repair a Loose Rear Bicycle Wheel: étape 3, image 1 de 2 How to Repair a Loose Rear Bicycle Wheel: étape 3, image 2 de 2
    • Assess damage of the dropout and wheel.
  4. How to Repair a Loose Rear Bicycle Wheel: étape 4, image 1 de 2 How to Repair a Loose Rear Bicycle Wheel: étape 4, image 2 de 2
    • Properly set the wheel back into dropout and put the chain back on the gear.
  5. How to Repair a Loose Rear Bicycle Wheel: étape 5, image 1 de 2 How to Repair a Loose Rear Bicycle Wheel: étape 5, image 2 de 2
    • Pull on the wheel so that the chain is tight, while tightening the rear axle just enough to hold it in place.
  6. How to Repair a Loose Rear Bicycle Wheel: étape 6, image 1 de 3 How to Repair a Loose Rear Bicycle Wheel: étape 6, image 2 de 3 How to Repair a Loose Rear Bicycle Wheel: étape 6, image 3 de 3
    • Check for misalignment or frame rubbing by pedaling without resistance.
  7. How to Repair a Loose Rear Bicycle Wheel: étape 7, image 1 de 3 How to Repair a Loose Rear Bicycle Wheel: étape 7, image 2 de 3 How to Repair a Loose Rear Bicycle Wheel: étape 7, image 3 de 3
    • Fully tighten the axle.
    • Turn the bike around.
    • Reattach the brake arm.
Lily Suggs
Membre depuis le 01/31/23
145 Réputation
1 tutoriel rédigé
Équipe
UC Davis, Team 4-8, Andersen Winter 2023 Membre de l'équipe UC Davis, Team 4-8, Andersen Winter 2023
UCD-ANDERSEN-W23S4G8
3 membres
1 tutoriel rédigé
1 commentaire de tutoriel
Axle alignment is crooked, which can cause wobbling. Loosen the axle nuts or quick-release skewer, align the wheel, and tighten it securely.
Bruno John - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 6
30 derniers jours : 67
Total : 1,469
