Aller au contenu principal
How to Replace a G-Shock GA201-1A Battery
Ce dont vous avez besoin
  1. How to Replace a G-Shock GA201-1A Battery, Battery: étape 1, image 1 de 3 How to Replace a G-Shock GA201-1A Battery, Battery: étape 1, image 2 de 3 How to Replace a G-Shock GA201-1A Battery, Battery: étape 1, image 3 de 3
    • Remove back cover by removing the four 6.2 mm Phillips #0 screws with the screwdriver.
    • Be careful not to lose the screws.
  2. How to Replace a G-Shock GA201-1A Battery: étape 2, image 1 de 1
    Outil utilisé dans cette étape :
    • Use the tweezers to remove the rubber gasket by lifting it.
  3. How to Replace a G-Shock GA201-1A Battery: étape 3, image 1 de 2 How to Replace a G-Shock GA201-1A Battery: étape 3, image 2 de 2
    • Lift the white plastic covering with a pair of tweezers.
    • Be delicate; if too much force is applied, the watch's interior can pop out.
  4. How to Replace a G-Shock GA201-1A Battery: étape 4, image 1 de 1
    • Peel off the protective sticker from the surface of the old battery.
  5. How to Replace a G-Shock GA201-1A Battery: étape 5, image 1 de 1
    • Use tweezers to bend the metal guide away from the old battery.
  6. How to Replace a G-Shock GA201-1A Battery: étape 6, image 1 de 1
    • Remove the old battery from the guide with tweezers.
  7. How to Replace a G-Shock GA201-1A Battery: étape 7, image 1 de 2 How to Replace a G-Shock GA201-1A Battery: étape 7, image 2 de 2
    • Slide the new battery into the frame and bend the metal guide onto the battery.
  8. How to Replace a G-Shock GA201-1A Battery: étape 8, image 1 de 2 How to Replace a G-Shock GA201-1A Battery: étape 8, image 2 de 2
    • Reset the proper time and date using the top-left "adjust" button.
    • For further instructions, consult your G-Shock GA-201 User Manual.
To reassemble your watch, follow these instructions in reverse order.
For optimal performance, after completing this guide, calibrate your newly installed battery.
Cordell Johnson
Membre depuis le 09/28/21
157 Réputation
1 tutoriel rédigé
Équipe
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 7
7 derniers jours : 81
30 derniers jours : 320
Total : 26,740
