Introduction
Use this guide to replace the ice maker in an older Whirlpool Refrigerator
The ice maker automatically produces ice which can be accessed either inside the freezer compartment, or dispensed through the freezer door.
When the ice maker fails, there is no ice available in the ice maker unit and none available to dispense.
This guide is based on a Whirlpool model ED5FTGXKQ02 refrigerator.
Ce dont vous avez besoin
Turn off your main water supply (if connected)
Unplug your device
Pull the handle of the refrigerator door towards you to open it.
Lift the ice maker flap.
Slide the ice maker flap into its slot.
Llift the ice bucket slightly and pull it towards you to remove it.
Push down on the ice maker cover.
Pull the bottom of the ice maker cover out.
Use a 1/4‑inch nut driver to loosen the two upper mounting screws.
Use a 1/4‑inch nut driver to remove the lower mounting screw.
Lift the ice maker up to release it from the upper mounting screws.
Move it gently away from the wall into the freezer.
Lower the ice maker partially to access the cable lock tab on the upper front of the ice maker.
Use a spudger or flat head screwdriver to press in the cable lock tab to release the cable.
Repair didn’t go as planned? Ask our Answers community for help.
