Aller au contenu principal
How to Wash and Dry Patagonia Waders
Ce dont vous avez besoin
  1. How to Wash and Dry Patagonia Waders, How to Wash and Dry Patagonia Waders: étape 1, image 1 de 3 How to Wash and Dry Patagonia Waders, How to Wash and Dry Patagonia Waders: étape 1, image 2 de 3 How to Wash and Dry Patagonia Waders, How to Wash and Dry Patagonia Waders: étape 1, image 3 de 3
    • Grab your waders and shake out any excess dirt.
    • Zip up any zippers on your waders.
  2. How to Wash and Dry Patagonia Waders: étape 2, image 1 de 3 How to Wash and Dry Patagonia Waders: étape 2, image 2 de 3 How to Wash and Dry Patagonia Waders: étape 2, image 3 de 3
    • Untangle the buckles.
    • Close or clip any fasteners on your buckles.
  3. How to Wash and Dry Patagonia Waders: étape 3, image 1 de 1
    • Put your waders in the washing machine.
  4. How to Wash and Dry Patagonia Waders: étape 4, image 1 de 3 How to Wash and Dry Patagonia Waders: étape 4, image 2 de 3 How to Wash and Dry Patagonia Waders: étape 4, image 3 de 3
    • Add the technical clothing detergent to the washing machine.
    • We recommend using Granger's Performance Cleaner.
    • Each detergent is slightly different, so you'll want to follow the directions on the package to determine the amount you'll need.
  5. How to Wash and Dry Patagonia Waders: étape 5, image 1 de 2 How to Wash and Dry Patagonia Waders: étape 5, image 2 de 2
    • Set the load size on the washing machine to small.
    • Set the water temperature on the washing machine to cold/cold.
    • Some technical washes need to be heat-set, so you'll want to check the directions on the package to determine the best water temperature for your brand of tech wash.
    • Run the washing machine on a gentle or normal wash cycle.
  6. How to Wash and Dry Patagonia Waders: étape 6, image 1 de 1
    • Once the washer has stopped, run the rinse cycle a second time.
  7. How to Wash and Dry Patagonia Waders: étape 7, image 1 de 2 How to Wash and Dry Patagonia Waders: étape 7, image 2 de 2
    • Hang up your waders to dry. You can do this on a laundry line, ladder, or tree branch.
    • Once you are sure that the waders are completely dry, turn them inside-out and allow the inside to dry completely.
  8. How to Wash and Dry Patagonia Waders: étape 8, image 1 de 3 How to Wash and Dry Patagonia Waders: étape 8, image 2 de 3 How to Wash and Dry Patagonia Waders: étape 8, image 3 de 3
    • Alternatively, you can put your waders in the dryer.
    • Place your waders in the dryer.
    • Set the dryer to a normal dry-cycle time on low heat.
    • Start the dryer.
    • You may have to run the dryer for several cycles to get your waders completely dry. Be patient, making sure you rearrange your waders inside the dryer for best results. Make sure they are dry inside and out to prevent the appearance of mold or mildew.
Ligne d'arrivée
2 autres ont terminé cette réparation.
Brittany McCrigler
Membre depuis le 03/05/12
88 580 Réputation
132 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Community
136 membres
15 118 tutoriels rédigés
Un commentaire
This was very helpful. Thank you for posting these instructions with easy-to-understand directions and pictures.
J P - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 11
30 derniers jours : 62
Total : 10,266
