Aller au contenu principal
How to clean iRobot Roomba 4100 optical sensors to fix Circle Dance
Ce dont vous avez besoin
  1. How to clean iRobot Roomba 4100 optical sensors to fix Circle Dance, Battery Pack: étape 1, image 1 de 1
    • Turn the Roomba upside down to be able to see the yellow battery pack.
  2. How to clean iRobot Roomba 4100 optical sensors to fix Circle Dance: étape 2, image 1 de 2 How to clean iRobot Roomba 4100 optical sensors to fix Circle Dance: étape 2, image 2 de 2
    • Remove the battery by placing your fingers into the two holes and firmly press your fingers against both sides of the battery.
    • Lift the battery directly up and out of the device.
  3. How to clean iRobot Roomba 4100 optical sensors to fix Circle Dance: étape 3, image 1 de 1
    • Line up the replacement battery’s larger tab side with the larger tab hole and the smaller tab side with the smaller tab hole.
    • Insert the replacement battery into the empty space and firmly press down onto the battery until two audible clicks are heard.
  4. How to clean iRobot Roomba 4100 optical sensors to fix Circle Dance, How to clean iRobot Roomba 4100 optical sensors to fix Circle Dance: étape 4, image 1 de 1
    • Begin by removing the rear particle bin.
  5. How to clean iRobot Roomba 4100 optical sensors to fix Circle Dance: étape 5, image 1 de 1
    • Next, locate the three screws on the iRobots hubcap/wheels. (You only need to unscrew one side)
  6. How to clean iRobot Roomba 4100 optical sensors to fix Circle Dance: étape 6, image 1 de 1
    • Using a Phillips Head screwdriver, remove all three screws on the side of the hubcap of the wheel.
    There are actually 4 screws holding the hubcap on. To get to the 4th screw, you need to loosen the top cover by removing all its screws. Note different lengths of screws.
    Albert Jeans - Réponse
    yes found that out during this operation
    MaryAnne - Réponse
  7. How to clean iRobot Roomba 4100 optical sensors to fix Circle Dance: étape 7, image 1 de 1
    • Gently slide the hubcap up and out of the wheel well of the Roomba.
    I have a fourth screw well up into the body on the hub cover. ~2.5cm into the body from the round hub outer circle.
    Ben Carr - Réponse
  8. How to clean iRobot Roomba 4100 optical sensors to fix Circle Dance: étape 8, image 1 de 1
    • Notice the wires attached to the hubcap. These are directly connected to the optical encoder.
  9. How to clean iRobot Roomba 4100 optical sensors to fix Circle Dance: étape 9, image 1 de 1
    • Using a can of compressed air, gently spray and clean the optical encoder until the dust had been removed.
  10. How to clean iRobot Roomba 4100 optical sensors to fix Circle Dance: étape 10, image 1 de 1
    • Using a screwdriver, gently remove the drive belt from the gear. This is the rubber band wrapped around the gear shaft.
  11. How to clean iRobot Roomba 4100 optical sensors to fix Circle Dance: étape 11, image 1 de 1
    • Slowly lift the gear from the gear shaft. Make sure you do not lose the drive belt.
  12. How to clean iRobot Roomba 4100 optical sensors to fix Circle Dance: étape 12, image 1 de 1
    • Thoroughly clean the exposed area of the wheel using either compressed air or a moist cotton swab. Be mindful of the exposed inner drive shaft when cleaning the wheel area to prevent any preexisting dust from entering the drive shaft.
    my hubcaps have 4 screws. it makes it muh more difficult.
    Don Paulgaard - Réponse
4 autres ont terminé cette réparation.
Christian
Membre depuis le 10/06/10
263 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team 20-7, Maness Fall 2010 Membre de l'équipe Cal Poly, Team 20-7, Maness Fall 2010
CPSU-MANESS-F10S20G7
6 membres
7 tutoriels rédigés
4 commentaires
Thanks for your advice. I cleaned the sensors on the wheels and still the unit was having a circular dance. From another site mentioning another model there could be a problem with the sensors behind the front bumper bar and yes that was the problem. They needed blowing out with a strong air gun. Now after extensive cleaning my Roomba is running like a dream :-)
photofil - Réponse
My problem as well with my Roomba scheduler. The black and white front wheel housing was packed with rug fiber. Cleaned it out and all is well.
Also have a roomba discovery. It has a different front wheel with out any apparent sensor.
Will Long - Réponse
I have a roomba4100 it will turn on it will try to go but will stop after 1second don't know what's wrong could it be the belt
Rodney - Réponse
I have a Roomba from 2002 (before the 400 series. This tutorial looks like it might apply, but I can only get 2 of the 3 screws off the hubcap of the wheel. The other one is blocked by the top cover.
Stephen Martinson - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 10
30 derniers jours : 19
Total : 14,580
