Aller au contenu principal
Pour réparer ensemble - Je crée un compte
How to make real espresso
  1. How to make real espresso, Preparation of the portafilter machine: étape 1, image 1 de 3 How to make real espresso, Preparation of the portafilter machine: étape 1, image 2 de 3 How to make real espresso, Preparation of the portafilter machine: étape 1, image 3 de 3
    • Before proceeding to the actual pleasure of brewing coffee, you need to make sure that the machine is hot enough and thus reaches operating temperature (116-117 degrees). This can be seen from three parameters:
    • 1) the temperature under the drip tray for the residual water.
    • 2) on the left, the pressure indicator for the steam (in German: Milchaufschäumer)
    • 3) on the right at the pressure indicator for the brewing rotor.
    • Normally, the portafilter heats up to operating temperature within 15-20 minutes.
    • After the operating temperature (116-117 degrees) has been reached, you should quickly follow two additional steps
    • Repeat the process 2-3 times
    Demander à FixBot
    Ajouter un commentaire
  2. How to make real espresso, Selection of portafilter and preparation: étape 2, image 1 de 3 How to make real espresso, Selection of portafilter and preparation: étape 2, image 2 de 3 How to make real espresso, Selection of portafilter and preparation: étape 2, image 3 de 3
    • For a delicious espresso, or for a good cappuccino base, it is always recommended to use a portafilter with single spout. For a Lungo/Americano (extended espresso) or if you want to brew coffee for 2 people, you can also use the double spout.
    • Please note: Whether you use the single spout or double spout, the portafilter must always be dry and clean for best results.
    • For the grinder, make the lower left selection, here everything is set optimally for a delicious cup of espresso.
    • Put on the sieve and let the time run completely into the carrier. This should be about 9 seconds. You can also stop earlier if you don't want it to be so short and strong. :-) To do this, just give the portafilter a quick double tap on the little "button" on the grinder.
    Demander à FixBot
  3. How to make real espresso, Tamp and co.: étape 3, image 1 de 3 How to make real espresso, Tamp and co.: étape 3, image 2 de 3 How to make real espresso, Tamp and co.: étape 3, image 3 de 3
    • Important: When brewing coffee from a portafilter, the coffee must always be pressed hard enough into the portafilter. Or in technical jargon also called " to tamp".
    • Place the portafilter with the ground coffee on a non-slip surface.
    • With the temper then use pressure to tamp down the coffee grounds evenly (as shown in the 2nd picture).
    • After tamping, it should look like in the 3rd picture.
    Demander à FixBot
  4. How to make real espresso, Inserting the portafilter and brewing: étape 4, image 1 de 3 How to make real espresso, Inserting the portafilter and brewing: étape 4, image 2 de 3 How to make real espresso, Inserting the portafilter and brewing: étape 4, image 3 de 3
    • After tamping, please insert the portafilter carefully into the holder and adjust it with a slight pressure. This should then look like the first picture of step 1.
    • Place your favorite cup or glass underneath ;-)
    • Place the reference lever upwards. If the previous steps have all been done as instructed in the guide, the machine should take about 5-6 seconds to properly start the brewing process. In barista jargon, this is called CODA DI TOPO (Italian for "mouse tail"). :-)
    • As explained in the steps before, the machine has a timer, you should definitely keep an eye on it during the process. The optimum brewing time is 20-30 seconds. Then slowly lower the reference lever again.
    Demander à FixBot
  5. How to make real espresso, Cleaning the machine and the pleasure afterwards: étape 5, image 1 de 1
    • Now we have reached the last step, the espresso is brewed and smells delicious. A thick, oily crema should be visible on the cup or in the glass.
    • To continue excellent taste and cleanliness, it is very important to clean everything afterwards.
    • Knock out the brew group at the drip tray under the grinder and rinse with warm water.
    • Confirm the reference lever and let the coffee that has stuck run out into the water tank
    • Adjust the portafilter back into the device, press the reference lever again and run it through again with hot water.
    Demander à FixBot
I hope you now enjoy your delicious espresso. If you repeat the whole process a few times, you'll get into a routine.
And very important, always remember to keep the machine and the portafilter scrupulously clean. :-)
Merci à ces traducteurs :
de en
100%
Ces traducteurs nous aident réparer le monde ! Vous voulez contribuer ?
Commencez à traduire ›
Maurizio Luciano
Membre depuis le 04/01/22
151 Réputation
1 tutoriel rédigé
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 7
30 derniers jours : 43
Total : 1,064
