Aller au contenu principal
How to repair the Eurolite N-19 Fog Machine
Ce dont vous avez besoin
  1. How to repair the Eurolite N-19 Fog Machine, Opening the fog machine: étape 1, image 1 de 1
    • Open the fog machine by removing the screws on the sides of the fog machine with the appropriate screwdriver.
    • Remove the outer casing of the fog machine.
  2. How to repair the Eurolite N-19 Fog Machine, Evaluating the problem: étape 2, image 1 de 1
    • If the fog machine does not heat up, a fuse or another heating element could be malfunctioning.
    • If no smoke is coming out of the fog machine, then the pump could be malfunctioning
  3. How to repair the Eurolite N-19 Fog Machine, Repairing the fog machine: étape 3, image 1 de 1
    • In this instance, all that was needed was a new heat fuse and new spade connectors
    • In this case, I needed to remove the heat fuse and the spade connectors then needed to connect the new heat fuse and spade connectors to their respective locations
    • The heat fuse sits under the bimetal. (Cannot be seen clearly in the picture)
  4. How to repair the Eurolite N-19 Fog Machine, Reassembling the fog machine: étape 4, image 1 de 1
    • To reassemble your machine, follow the steps for diassembly in reverse order.
7 autres ont terminé cette réparation.
rjay
Membre depuis le 09/29/12
233 Réputation
1 tutoriel rédigé
23 commentaires
My fogger heater is jam how can I clean it?
vishal_kishor777 - Réponse
hmm… I think I could have written a better guide myself. Okay so I have a 3 pin XLR for phase does anyone know how this works also I noted that the fuse was melted into its holster and the pump seems dead. My Fogger also has some kind of potentiometer which controls the heating element which is like a ceramic sandwich and two spark plugs… I also was wondering if glycerin fog juice can be made with vegetable glycerin or the glycol type or if this is what cloggs the machine. Also will clr work or be dangerous fume wise? Can you market glycerine as fog juice thickener like STP fuel additives for cars?? g0pg.xyz is my website you can learn how to force push graphite if you look for the post with yoda!
Ember Leona - Réponse
Where can I buy a fuse like this? Have looked over the net, but could not find any shops that would sell CH-15 fuse, used in this fog machine. If anyone knows about this, please share info. Thanks! By the way, I’m based in EU.
Giedrius Stasiulis - Réponse
I would make a post on Halloweenform.com
Mad_as_a_hatter -
My fog machine is not pumping out smoke
Ohwaga Kerry - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 68
30 derniers jours : 262
Total : 63,809
