Aller au contenu principal
Huawei Honor 10 Loudspeaker Unit Removal
Ce dont vous avez besoin
  1. Huawei Honor 10 Loudspeaker Unit Removal, Rear Glass: étape 1, image 1 de 1
    • Before you begin, switch off your phone.
    • Apply a heated iOpener to a long edge of the phone to loosen the adhesive beneath the rear glass. Apply the iOpener for at least two minutes.
  2. Huawei Honor 10 Loudspeaker Unit Removal: étape 2, image 1 de 3 Huawei Honor 10 Loudspeaker Unit Removal: étape 2, image 2 de 3 Huawei Honor 10 Loudspeaker Unit Removal: étape 2, image 3 de 3
    • If the phone's rear glass is cracked, the suction cup may not stick. Try lifting it with strong tape, or superglue the suction cup in place and allow it to cure so you can proceed.
    • Press a suction cup onto the back cover.
    • Lift the back cover's right edge with your suction cup, opening a slight gap between the back cover and the frame.
    • Insert the tip of an opening pick in the gap you created and slide it to the bottom right corner.
  3. Huawei Honor 10 Loudspeaker Unit Removal: étape 3, image 1 de 2 Huawei Honor 10 Loudspeaker Unit Removal: étape 3, image 2 de 2
    • Apply more heat if the adhesive becomes hard to cut. During the removal process, the back cover is under tension all the time and is likely to break if the adhesive isn't softened enough.
    • Insert a second opening pick at the bottom right corner of the rear glass.
    • Slide the opening pick along the bottom edge of the rear glass to cut the adhesive and leave it in the bottom left corner.
  4. Huawei Honor 10 Loudspeaker Unit Removal: étape 4, image 1 de 3 Huawei Honor 10 Loudspeaker Unit Removal: étape 4, image 2 de 3 Huawei Honor 10 Loudspeaker Unit Removal: étape 4, image 3 de 3
    • Insert a third opening pick at the bottom left corner of the rear glass.
    • Slide the opening pick along the left edge of the rear glass to cut the adhesive.
    • Leave the opening pick at the top left corner of the rear glass.
  5. Huawei Honor 10 Loudspeaker Unit Removal: étape 5, image 1 de 2 Huawei Honor 10 Loudspeaker Unit Removal: étape 5, image 2 de 2
    • Insert a fourth opening pick at the top left corner of the rear glass.
    • Slide the opening along the top edge of the rear glass and cut the remaining adhesive with it.
  6. Huawei Honor 10 Loudspeaker Unit Removal: étape 6, image 1 de 2 Huawei Honor 10 Loudspeaker Unit Removal: étape 6, image 2 de 2
    • Carefully lift the rear glass of the Huawei Honor 10 and remove it.
  7. Huawei Honor 10 Loudspeaker Unit Removal, Battery disconnect: étape 7, image 1 de 3 Huawei Honor 10 Loudspeaker Unit Removal, Battery disconnect: étape 7, image 2 de 3 Huawei Honor 10 Loudspeaker Unit Removal, Battery disconnect: étape 7, image 3 de 3
    • Use a pair of tweezer to carefully peel the black foil off the loudspeaker and daughterboard cover.
    • Remove the foil completely.
  8. Huawei Honor 10 Loudspeaker Unit Removal: étape 8, image 1 de 1
    • Remove the three Phillips #00 screws (2.9 mm length) that secure the metal bracket on top of the battery, interconnect, and display flex cable.
  9. Huawei Honor 10 Loudspeaker Unit Removal: étape 9, image 1 de 2 Huawei Honor 10 Loudspeaker Unit Removal: étape 9, image 2 de 2
    Outil utilisé dans cette étape :
    J'achète
    • Use a pair of tweezers to remove the metal shield that covers the connectors of the interconnect cable, the battery and the display flex cable.
  10. Huawei Honor 10 Loudspeaker Unit Removal: étape 10, image 1 de 2 Huawei Honor 10 Loudspeaker Unit Removal: étape 10, image 2 de 2
    • Use a spudger to pry up and disconnect the battery flex cable.
  11. Huawei Honor 10 Loudspeaker Unit Removal, Loudspeaker Unit: étape 11, image 1 de 1
    • Remove the seven Phillips screws securing the loudspeaker unit:
    • Three silver 2.9 mm long screws
    • Four black 3.4 mm long screws
  12. Huawei Honor 10 Loudspeaker Unit Removal: étape 12, image 1 de 3 Huawei Honor 10 Loudspeaker Unit Removal: étape 12, image 2 de 3 Huawei Honor 10 Loudspeaker Unit Removal: étape 12, image 3 de 3
    • There's a little bit of adhesive under the loudspeaker. It's possible to remove the loudspeaker without heating the adhesive but if you're having a hard time removing it, you can use an iOpener to soften the adhesive.
    • Slide the flat end of a spudger under the right side of the loudspeaker unit.
    • Pry up the loudspeaker unit until you can get a good grip.
    • Remove the loudspeaker unit.
4 autres ont terminé cette réparation.
Dominik Schnabelrauch
Membre depuis le 11/23/16
211 821 Réputation
682 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
140 membres
18 078 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 7
30 derniers jours : 35
Total : 3,672
