Aller au contenu principal
Huawei Honor 8 Front Camera Replacement
Ce dont vous avez besoin
  1. Huawei Honor 8 Front Camera Replacement, Rear Glass: étape 1, image 1 de 1
    • Before you begin, switch off your phone.
    • Apply a heated iOpener to the back of the phone to loosen the adhesive beneath the rear glass. Apply the iOpener for at least two minutes.
  2. Huawei Honor 8 Front Camera Replacement: étape 2, image 1 de 3 Huawei Honor 8 Front Camera Replacement: étape 2, image 2 de 3 Huawei Honor 8 Front Camera Replacement: étape 2, image 3 de 3
    • If the phone's rear glass is cracked, the suction cup may not stick. Try lifting it with strong tape, or superglue the suction cup in place and allow it to cure so you can proceed.
    • Secure a suction handle to the lower edge of the rear glass, as close to the edge as possible.
    • Lift the rear glass with the suction cup to create a small gap between the glass and the frame.
    • Insert an opening pick into the gap.
    • If you have trouble, apply more heat to further soften the adhesive. Follow the iOpener instructions to avoid overheating.
    • Slide the opening pick to the bottom right corner.
  3. Huawei Honor 8 Front Camera Replacement: étape 3, image 1 de 2 Huawei Honor 8 Front Camera Replacement: étape 3, image 2 de 2
    • Insert a second opening pick and slide it to the bottom left corner to cut the adhesive.
    • Leave the opening picks in place to prevent the adhesive from resealing.
  4. Huawei Honor 8 Front Camera Replacement: étape 4, image 1 de 3 Huawei Honor 8 Front Camera Replacement: étape 4, image 2 de 3 Huawei Honor 8 Front Camera Replacement: étape 4, image 3 de 3
    • The fingerprint cable is located above the power and volume buttons on this side of the phone. Only use the tip of the opening pick in this area to avoid damage.
    • Insert a third opening pick at the bottom left corner.
    • Start to slide the tip of the opening pick from the bottom left corner along the side to cut the adhesive.
    • Leave the opening pick in its place at the top left corner to prevent the adhesive from resealing.
  5. Huawei Honor 8 Front Camera Replacement: étape 5, image 1 de 2 Huawei Honor 8 Front Camera Replacement: étape 5, image 2 de 2
    • If the adhesive gets hard to cut it most likely cooled down. Use your iOpener to reheat it.
    • Insert a fourth opening pick under the top left corner of the rear glass.
    • Slide the opening pick along the top edge of the phone to cut the adhesive.
    • Leave the opening pick in the top right corner to prevent the adhesive from resealing.
  6. Huawei Honor 8 Front Camera Replacement: étape 6, image 1 de 2 Huawei Honor 8 Front Camera Replacement: étape 6, image 2 de 2
    • Insert a fifth opening pick at the top right corner of the phone.
    • Slide the opening pick along the right side to cut the remaining adhesive.
    • The fingerprint cable is still connected to the motherboard. Don't try to remove the rear glass all the way yet.
  7. Huawei Honor 8 Front Camera Replacement: étape 7, image 1 de 2 Huawei Honor 8 Front Camera Replacement: étape 7, image 2 de 2
    • Carefully lift the rear glass and fold it to the left side of the Honor 8.
  8. Huawei Honor 8 Front Camera Replacement: étape 8, image 1 de 1
    • Remove the Phillips #00 screw (2.8 mm length) that secures the metal bracket on top of the fingerprint flex connector.
  9. Huawei Honor 8 Front Camera Replacement: étape 9, image 1 de 2 Huawei Honor 8 Front Camera Replacement: étape 9, image 2 de 2
    Outil utilisé dans cette étape :
    • Use a pair of tweezers to remove the metal bracket that sits on top of the fingerprint and display flex connectors.
  10. Huawei Honor 8 Front Camera Replacement: étape 10, image 1 de 2 Huawei Honor 8 Front Camera Replacement: étape 10, image 2 de 2
    • Use a spudger to pry up and disconnect the fingerprint flex connector.
  11. Huawei Honor 8 Front Camera Replacement, Midframe Bezel: étape 11, image 1 de 1
    • Remove these Phillips #00 screws securing the midframe bezel:
    • Eight screws with 3.5 mm length
    • Eight screws with 2.9 mm length
    • Some screws might be covered with a tamper proof sticker.
  12. Huawei Honor 8 Front Camera Replacement: étape 12, image 1 de 3 Huawei Honor 8 Front Camera Replacement: étape 12, image 2 de 3 Huawei Honor 8 Front Camera Replacement: étape 12, image 3 de 3
    • Insert an opening pick underneath the top right edge of the midframe bezel.
    • Use the opening pick to pry up the midframe bezel.
    • Insert the opening pick underneath the bottom left corner of the bezel and pry it up.
  13. Huawei Honor 8 Front Camera Replacement: étape 13, image 1 de 2 Huawei Honor 8 Front Camera Replacement: étape 13, image 2 de 2
    • Insert the long edge of an opening pick in the seam between the midframe and the bezel on the left side of the phone.
    • Slide the opening pick along the left side of the phone to cut the adhesive underneath the midframe bezel.
  14. Huawei Honor 8 Front Camera Replacement: étape 14, image 1 de 2 Huawei Honor 8 Front Camera Replacement: étape 14, image 2 de 2
    • Repeat the procedure on the right edge of the phone to cut the adhesive underneath the midframe bezel.
  15. Huawei Honor 8 Front Camera Replacement: étape 15, image 1 de 2 Huawei Honor 8 Front Camera Replacement: étape 15, image 2 de 2
    • Carefully grasp the midframe bezel from the bottom corners and lift it upwards.
    • Remove the midframe bezel.
  16. Huawei Honor 8 Front Camera Replacement, Battery Disconnect: étape 16, image 1 de 2 Huawei Honor 8 Front Camera Replacement, Battery Disconnect: étape 16, image 2 de 2
    • Use a spudger to pry up and disconnect the battery flex cable.
  17. Huawei Honor 8 Front Camera Replacement, Front Facing Camera: étape 17, image 1 de 2 Huawei Honor 8 Front Camera Replacement, Front Facing Camera: étape 17, image 2 de 2
    • Use a spudger to pry up and disconnect the front camera flex cable from its motherboard socket.
  18. Huawei Honor 8 Front Camera Replacement: étape 18, image 1 de 2 Huawei Honor 8 Front Camera Replacement: étape 18, image 2 de 2
    • Use a pair of tweezers to carefully lift the front camera out of its recess and remove it.
If possible, turn on your phone and test your repair before installing new adhesive and resealing the phone.
Dominik Schnabelrauch
Membre depuis le 11/23/16
232 053 Réputation
682 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
121 membres
19 839 tutoriels rédigés
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 1
30 derniers jours : 19
Total : 520
