Introduction
Use this guide to replace the charging port in your Huawei Mate 10 Pro smartphone.
Ce dont vous avez besoin
Switch off your phone.
Prepare an iOpener and apply it to the back of the phone for about two minutes to loosen the adhesive beneath the back cover.
Outil utilisé dans cette étape :Halberd Spudger$2.99
Lift up the back cover with a suction cup until you can insert the flat end of a halberd spudger.
Use the halberd spudger to cut the adhesive beneath the back cover on all sides of the phone.
Remove the twelve Phillips #00 screws.
Carefully remove the shields on top of the motherboard and the charging board.
Use a spudger to disconnect the charging port flex cable from the motherboard and from the daughterboard.
18 autres ont terminé cette réparation.
2 commentaires de tutoriel
Great tutorial! It has been a month without being able to charge my phone, and now it charges 2x as fast with my repair.
I recommend testing the USB C flex cable assembly before you reassemble the phone. As soon as it’s connected to the upper connector and the battery is plugged in the phone should be charging. Mine was broken from the factory but I went to a great local repair shop and got a new one, the guy said 1 out of 15 is broken from the factory. Great tutorial, successful repair.
