Aller au contenu principal
Huawei Mate 9 Display Replacement
Ce dont vous avez besoin
  1. Huawei Mate 9 Display Replacement, Back Cover: étape 1, image 1 de 2 Huawei Mate 9 Display Replacement, Back Cover: étape 1, image 2 de 2
    • First switch off your phone and remove the SIM card tray.
  2. Huawei Mate 9 Display Replacement: étape 2, image 1 de 2 Huawei Mate 9 Display Replacement: étape 2, image 2 de 2
    • Remove both screws on the bottom with a Torx T2 screwdriver.
    • Use a plastic opening tool to get between the display and the case. Open the smartphone by carefully prying out the display with all the parts out of the case.
    • Don't open the phone all the way, yet. The fingerprint sensor cable is still connected to the back cover.
  3. Huawei Mate 9 Display Replacement: étape 3, image 1 de 2 Huawei Mate 9 Display Replacement: étape 3, image 2 de 2
    • Swing open the phone to the right side.
    • Disconnect the fingerprint sensor cable with a spudger.
  4. Huawei Mate 9 Display Replacement, Battery Disconnect: étape 4, image 1 de 1
    • Carefully peel off the plastic sticker that holds both cables to the battery.
  5. Huawei Mate 9 Display Replacement: étape 5, image 1 de 1
    • Remove the water indicator sticker and the Phillips #00 screw beneath it, that holds the cable bracket in its place.
  6. Huawei Mate 9 Display Replacement: étape 6, image 1 de 1
    • Remove the cable bracket.
  7. Huawei Mate 9 Display Replacement: étape 7, image 1 de 3 Huawei Mate 9 Display Replacement: étape 7, image 2 de 3 Huawei Mate 9 Display Replacement: étape 7, image 3 de 3
    • Use a spudger to disconnect the interconnect, the battery and the display flex cable.
  8. Huawei Mate 9 Display Replacement, Display: étape 8, image 1 de 3 Huawei Mate 9 Display Replacement, Display: étape 8, image 2 de 3 Huawei Mate 9 Display Replacement, Display: étape 8, image 3 de 3
    • It's not required to remove the battery in order to remove the display of the Huawei Mate 9.
    • Disconnect the antenna cable and remove it carefully.
    • Remove the five Phillips #00 screws that hold the daughter board and loudspeaker in its place.
  9. Huawei Mate 9 Display Replacement: étape 9, image 1 de 2 Huawei Mate 9 Display Replacement: étape 9, image 2 de 2
    • Remove the metal shield that covers the connection of the motherboard flex cable.
    • Use a spudger to unplug the motherboard flex cable and remove it.
  10. Huawei Mate 9 Display Replacement: étape 10, image 1 de 2 Huawei Mate 9 Display Replacement: étape 10, image 2 de 2
    • Use a spudger to disconnect the loudspeaker and the charging port flex cable from the daughterboard.
  11. Huawei Mate 9 Display Replacement: étape 11, image 1 de 3 Huawei Mate 9 Display Replacement: étape 11, image 2 de 3 Huawei Mate 9 Display Replacement: étape 11, image 3 de 3
    • Use a spudger to carefully lever up the daughterboard and remove it. Don't break the small clamps that hold down the daughter board but press them a little bit to the side to make the removal easier.
    • Use a spudger to remove the loudspeaker and the charging port. There is some adhesive underneath and the unit might be a little bit sticky.
    • If you're having a hard time while removing the loudspeaker you can use an iOpener to loosen the adhesive and try it again.
  12. Huawei Mate 9 Display Replacement: étape 12, image 1 de 3 Huawei Mate 9 Display Replacement: étape 12, image 2 de 3 Huawei Mate 9 Display Replacement: étape 12, image 3 de 3
    • Use an iOpener to loosen the adhesive beneath the display. Focus on the top and bottom area of it.
    • After loosening the adhesive in the upper area of your phone, use an iFlex or opening pick and insert it carefully between the mid frame and your display.
    • Do not insert the tool more than approximately 1/16 of an inch on the sides.
    • Loosen the adhesive by sliding the along the mid frame.
  13. Huawei Mate 9 Display Replacement: étape 13, image 1 de 3 Huawei Mate 9 Display Replacement: étape 13, image 2 de 3 Huawei Mate 9 Display Replacement: étape 13, image 3 de 3
    • Then carefully slide around the whole mid frame.
    • If you're having a hard time while loosening the adhesive beneath the display you can reuse the iOpener and try it again.
    • After you loosened all the adhesive, start to slowly lift up the display from the bottom of your phone.
  14. Huawei Mate 9 Display Replacement: étape 14, image 1 de 2 Huawei Mate 9 Display Replacement: étape 14, image 2 de 2
    • To completely remove the display you need to thread the flex cable through the gap in the mid frame.
    • When reassembling your phone apply new adhesive where it is necessary.
To reassemble your device, follow these instructions in reverse order. When reassembling apply new adhesive where it is necessary.
14 autres ont terminé cette réparation.
Dominik Schnabelrauch
Membre depuis le 11/23/16
229 784 Réputation
682 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
119 membres
19 481 tutoriels rédigés
7 commentaires
I have issue with the assembly process. Im adding 3m adhesive tape that I received with replacement screen, and everything looks fine. But after inserting phone into aluminium back the screen pop out int the middle of frame, delaminating and showing backlight of lcd. The adhesive just not hold it enough..
gingerboi66 - Réponse
The iFlex isn’t listed in the tools.
Sean Hannold - Réponse
Check, now it is listed. Thanks for the note.
Tobias Isakeit -
it’s almost impossible to remove the battery without damaging it!
My advice to you is to buy the LCD screen with the battery included.
madani_salar - Réponse
Hello,
do i have to remove the battery to change the display? That means is the removing of the battery absolutely necessary?
Greetings,
Mark
Mark D. - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 9
7 derniers jours : 57
30 derniers jours : 182
Total : 20,262
