Aller au contenu principal
Huawei P10 Lite Back cover Replacement
Ce dont vous avez besoin
  1. Huawei P10 Lite Back cover Replacement, Back cover: étape 1, image 1 de 3 Huawei P10 Lite Back cover Replacement, Back cover: étape 1, image 2 de 3 Huawei P10 Lite Back cover Replacement, Back cover: étape 1, image 3 de 3
    • Insert the tip of an opening pick between the back cover and the mid frame and slide it around the phone, to cut the adhesive.
    • Using a suction handle to lift the back cover may help to get an initial gap for the opening pick to put in.
    • If the adhesive is hard to cut, use an iOpener to loosen it.
  2. Huawei P10 Lite Back cover Replacement: étape 2, image 1 de 3 Huawei P10 Lite Back cover Replacement: étape 2, image 2 de 3 Huawei P10 Lite Back cover Replacement: étape 2, image 3 de 3
    • After you cut the adhesive on every edge, twist your opening pick, to separate the rear cover from the phone.
    • Flip the rear cover over to the right side of the phone.
  3. Huawei P10 Lite Back cover Replacement: étape 3, image 1 de 2 Huawei P10 Lite Back cover Replacement: étape 3, image 2 de 2
    Outil utilisé dans cette étape :
    • Use a pair of tweezers to remove the sticker.
    • Remove the two Phillips #00 screws.
    • Remove the four 2.5 mm Phillips #00 screws.
  4. Huawei P10 Lite Back cover Replacement: étape 4, image 1 de 2 Huawei P10 Lite Back cover Replacement: étape 4, image 2 de 2
    • Use tweezers to remove the mainboard shield.
    • Use the flat end of a spudger to disconnect the finger print sensor flex cable.
    • When reassembling apply new adhesive where it is necessary.
15 autres ont terminé cette réparation.
Dominik Schnabelrauch
Membre depuis le 11/23/16
228 969 Réputation
682 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
118 membres
19 410 tutoriels rédigés
6 commentaires
Great guide, but how do I move the fingerprint sensor to the new cover?
mela ross - Réponse
You need to warm the adhesive so it can be loose
Adwell Cellular -
What adhesive should I use? Thank you!
Calin GV - Réponse
Nice guide! Thanks! I got a little question about the coloring of the back panel. What kind of coloring is it? Is it a coating you can take off, or is it more like a layer of paint you can scrape off? I am wondering, because I want to clear the back of my Huawei P10 lite. I hope it’s possible though.
Daan - Réponse
Can you send me please back cover.
I'm from Nepal .
Md Usman - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 18
30 derniers jours : 60
Total : 39,407
