Introduction
This guide will show you how to disassemble your Ionic Breeze for repairs or cleaning.
Ce dont vous avez besoin
Start by turning off the device, unplugging it and remove the Ionic Breeze "filter". It's more of a tri-blade object rather than a filter but you get the idea.
Next, lay the device flat and remove the 4 screws holding the Ionic Breeze to its base and pull it away from the device.
Remove the 2 hidden screws found beneath the base with your #1 screwdriver.
Remove the 12 smaller screws with your #1 hobby screwdriver.
Remove the 4 screws attaching the top of the device to the body with your #1 screwdriver.
Separate the two halves of the body.
Although I have separated the top from the main body in this picture you do not need to worry about this now. We will do this in a later step.
Photos depict where to desolder the power cables connection points. Remove any hot glue that may be holding down the cables. These devices are a little seasoned so the glue should not be hard to remove by hand.
Remember to pull the ground cable completely through the PCB. We will re-thread it back through during the reassembly process.
Gently lift up on the top in order to separate it from the half that it is attached to.
Pull the plastic piece out from its retaining slot.
At this point, the PCB may make a slight popping sound. It didn't break! It simply popped out of it's retaining slot as well as you removed the plastic piece.
Remove the single screw that's hidden underneath the top/power button unit.
If you look at the smaller bottom PCB you will notice 2 wires on both sides of it. Slightly above that there should be some hot glue holding these wires to the plastic housing. You cannot see it in the picture but its estimated location is highlighted in red. Remove this and any hot glue that's holding the main power cable in place.
When the glue is removed gently lift the lower plastic piece and the bottom PCB at the same time. It will come out as one whole piece.
Place the electronics off to the side.
Wrap both ends of the power cable real tight with plastic wrap and wrap the entire thing in electrical tape.
3 autres ont terminé cette réparation.
3 commentaires
I disassembled my old ionic breeze after it failed to see what electronic parts I could salvage. I got everything out, and when I was examining the base electronics - the part with the flyback transformer, I received a very long and nasty electrical shock to my hand. I was surprised as it had been unplugged for over 30 minutes, and I thought it was broken. I will meter the base before I pick it up again.
Thanks for the Ionic breeze disassembly instructions. My unit was just stone dead. Because of karllindheimer”s comments, I was careful to discharge the 220uF cap before I dug into the PCB. Like him it still had quite a kick, I had to short the cap 3 or 4 times before it was fully discharged! i didn’t expect the unit to be quite as sophisticated as it was, it looked like a modified tv set flyback circuit! Unfortunately the fuse was still good and I couldn’t immediately see any cooked components. I’ll look around for a troubleshooting manual, if I can’t find one I’ll junk this unit.
Hey guys, to wrap this up, I watched https://www.youtube.com/watch?v=MWb54DK5... (FixitFrank) on this Ionic Breeze unit. The problem was just the power button. Guess I should have been more observant, thanks Frank!
