Aller au contenu principal
JBL Charge 5 Buttons Replacement
Ce dont vous avez besoin
  1. JBL Charge 5 Buttons Replacement, Fabric Case: étape 1, image 1 de 3 JBL Charge 5 Buttons Replacement, Fabric Case: étape 1, image 2 de 3 JBL Charge 5 Buttons Replacement, Fabric Case: étape 1, image 3 de 3
    • Ensure that the device is fully powered off and no cables are attached before proceeding with the repair.
    • This fabric cover is secured with plastic clips only. Depending on the model, the cover may be secured by both plastic clips and screws.
    • Insert the flat end of the Jimmy into the seam located between the fabric cover on the right side of the seam.
    • Pry upward on the fabric cover to release plastic clips on the right side of the seam.
  2. JBL Charge 5 Buttons Replacement: étape 2, image 1 de 3 JBL Charge 5 Buttons Replacement: étape 2, image 2 de 3 JBL Charge 5 Buttons Replacement: étape 2, image 3 de 3
    • Insert the flat end of the Jimmy into the seam between the fabric cover at the center of the seam and the left side of the seam.
    • Use the Jimmy to pry open the edge with the rubber texture, releasing the remaining plastic clips.
  3. JBL Charge 5 Buttons Replacement: étape 3, image 1 de 3 JBL Charge 5 Buttons Replacement: étape 3, image 2 de 3 JBL Charge 5 Buttons Replacement: étape 3, image 3 de 3
    • Use your hands to gently open the two halves of the casing and slide the fabric cover off of the interior housing.
  4. JBL Charge 5 Buttons Replacement, Buttons: étape 4, image 1 de 2 JBL Charge 5 Buttons Replacement, Buttons: étape 4, image 2 de 2
    • Use an iFixit opening tool, to softly pry open each side of the button cover.
    • By removing the rubber button cover, the adhesives will break. This may cause the device to lose its waterproof feature.
  5. JBL Charge 5 Buttons Replacement: étape 5, image 1 de 3 JBL Charge 5 Buttons Replacement: étape 5, image 2 de 3 JBL Charge 5 Buttons Replacement: étape 5, image 3 de 3
    • Use a plastic spudger, and softly pry up on the sides of the button control board to remove it from the slot.
    • Be cautious and don't pull the board all of the way out. The board is connected to the device by a ribbon cable.
  6. JBL Charge 5 Buttons Replacement: étape 6, image 1 de 3 JBL Charge 5 Buttons Replacement: étape 6, image 2 de 3 JBL Charge 5 Buttons Replacement: étape 6, image 3 de 3
    • Pinch the no-fuss ribbon cable connector, and gently pull the cable out to disconnect it from the board.
    • Remove the button board.
Kat Whaley
Membre depuis le 09/13/23
753 Réputation
6 tutoriels rédigés
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 4
30 derniers jours : 48
Total : 291
