Aller au contenu principal
Jabra CRUISER2 Status Display Replacement
Ce dont vous avez besoin
  1. Jabra CRUISER2 Status Display Replacement, Front Plate: étape 1, image 1 de 1
    • Use the iOpener tool to unglue the adhesive of the device. The link to the iOpener instructions are listed below.
    • Instructions iOpener
  2. Jabra CRUISER2 Status Display Replacement: étape 2, image 1 de 1
    • Place the flat head of the bigger plastic opening tool in between the front plate and back plate.
    • Pull the tool toward the back of the device to pry it open.
    • Repeat this process over all edges of the device.
  3. Jabra CRUISER2 Status Display Replacement: étape 3, image 1 de 1
    • Open up the device by pulling the front plate straight up from the back plate.
  4. Jabra CRUISER2 Status Display Replacement, Motherboard: étape 4, image 1 de 2 Jabra CRUISER2 Status Display Replacement, Motherboard: étape 4, image 2 de 2
    • Carefully detach the wire running from the speaker to the motherboard by unplugging it from the white socket.
  5. Jabra CRUISER2 Status Display Replacement: étape 5, image 1 de 1
    • Using the PH000, unscrew the three 4.55 mm screws in the motherboard.
    • The names of the screwdriver heads are listed on the sides of each head.
  6. Jabra CRUISER2 Status Display Replacement: étape 6, image 1 de 1
    • Remove the motherboard from the device by lifting it up from the back plate.
  7. Jabra CRUISER2 Status Display Replacement, Status Display: étape 7, image 1 de 1
    • Using the PH000, unscrew the three 4.6mm screws in the status display.
  8. Jabra CRUISER2 Status Display Replacement: étape 8, image 1 de 2 Jabra CRUISER2 Status Display Replacement: étape 8, image 2 de 2
    • Disconnect the wires connecting the status display to the back plate. Do this by pulling the wire from the black socket.
    • Do this with the wires on both sides of the status board.
  9. Jabra CRUISER2 Status Display Replacement: étape 9, image 1 de 1
    • Remove the status display by lifting it off of the back plate.
Spartacus
Membre depuis le 10/17/14
636 Réputation
5 tutoriels rédigés
Équipe
Baylor, Team 8-13, Williams Fall 2014 Membre de l'équipe Baylor, Team 8-13, Williams Fall 2014
BU-WILLIAMS-F14S8G13
3 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 2
30 derniers jours : 9
Total : 503
