Aller au contenu principal
Jumper Angelsounds JPD-100S Volume Knob Replacement
Ce dont vous avez besoin
  1. Jumper Angelsounds JPD-100S Volume Knob Replacement, Motherboard: étape 1, image 1 de 1
    • Access the battery compartment
    • Remove the battery compartment lid and set it aside.
    • Disconnect the battery and set it aside.
  2. Jumper Angelsounds JPD-100S Volume Knob Replacement: étape 2, image 1 de 2 Jumper Angelsounds JPD-100S Volume Knob Replacement: étape 2, image 2 de 2
    • Puncture the sticker in the battery compartment with a spudger to access the screw beneath it.
  3. Jumper Angelsounds JPD-100S Volume Knob Replacement: étape 3, image 1 de 1
    • Remove the 7mm Phillips #1 screw from the battery compartment.
    • Place the screw in a secure place.
  4. Jumper Angelsounds JPD-100S Volume Knob Replacement: étape 4, image 1 de 2 Jumper Angelsounds JPD-100S Volume Knob Replacement: étape 4, image 2 de 2
    • Begin prying open the device.
    • Insert a plastic opening tool into the side groove about 2cm from the pink plastic component and pry open one side of the device.
    • Once the side is separated, leave the opening tool inside to prevent the two sides from closing.
  5. Jumper Angelsounds JPD-100S Volume Knob Replacement: étape 5, image 1 de 2 Jumper Angelsounds JPD-100S Volume Knob Replacement: étape 5, image 2 de 2
    • Insert another plastic opening tool into the groove opposite to the side of the tool already inserted.
    • Create separation on that side until the white plastic component comes off entirely.
    • Place the white plastic component in a secure place.
  6. Jumper Angelsounds JPD-100S Volume Knob Replacement: étape 6, image 1 de 1
    • With your hand, remove the pink component.
  7. Jumper Angelsounds JPD-100S Volume Knob Replacement: étape 7, image 1 de 1
    • Remove the 7mm Phillips #1 screw in the middle of the motherboard.
  8. Jumper Angelsounds JPD-100S Volume Knob Replacement, Volume Knob: étape 8, image 1 de 2 Jumper Angelsounds JPD-100S Volume Knob Replacement, Volume Knob: étape 8, image 2 de 2
    • Remove the white glue on the volume knob by peeling it off or gently using tweezers to pull it out.
    • Allow approximately 10 minutes for the soldering station to heat up before using.
  9. Jumper Angelsounds JPD-100S Volume Knob Replacement: étape 9, image 1 de 2 Jumper Angelsounds JPD-100S Volume Knob Replacement: étape 9, image 2 de 2
    • Remove the 5mm Phillips #00 screw holding the volume knob to the motherboard.
    • Place the screw and volume knob in a secure, safe place.
  10. Jumper Angelsounds JPD-100S Volume Knob Replacement: étape 10, image 1 de 3 Jumper Angelsounds JPD-100S Volume Knob Replacement: étape 10, image 2 de 3 Jumper Angelsounds JPD-100S Volume Knob Replacement: étape 10, image 3 de 3
    • Unsolder the five points holding the volume knob to the motherboard.
    • Carefully place the soldering iron down, as you will need it for reassembly.
Melanie Orozco
Membre depuis le 08/31/15
143 Réputation
1 tutoriel rédigé
Équipe
USF Tampa, Team 6-1, Remmell Fall 2015 Membre de l'équipe USF Tampa, Team 6-1, Remmell Fall 2015
USFT-REMMELL-F15S6G1
6 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 1
30 derniers jours : 3
Total : 165
