Aller au contenu principal
Kawasaki Ninja 300 Seat Replacement
Ce dont vous avez besoin
  1. Kawasaki Ninja 300 Seat Replacement, Seat: étape 1, image 1 de 3 Kawasaki Ninja 300 Seat Replacement, Seat: étape 1, image 2 de 3 Kawasaki Ninja 300 Seat Replacement, Seat: étape 1, image 3 de 3
    • Locate the bolt holding the side seat cover in place and remove it using a 4mm hex key.
    • Make sure to also remove the bolt's washer.
  2. Kawasaki Ninja 300 Seat Replacement: étape 2, image 1 de 3 Kawasaki Ninja 300 Seat Replacement: étape 2, image 2 de 3 Kawasaki Ninja 300 Seat Replacement: étape 2, image 3 de 3
    • If you're working in cold conditions, be careful not to break the side seat cover.
    • Reach under the side seat cover and firmly pull it out to unseat it from its rubber clips. There is one at the rear of the cover and two at the front.
  3. Kawasaki Ninja 300 Seat Replacement: étape 3, image 1 de 3 Kawasaki Ninja 300 Seat Replacement: étape 3, image 2 de 3 Kawasaki Ninja 300 Seat Replacement: étape 3, image 3 de 3
    • Locate the seat bolt and remove it using a 5mm hex key.
    • It's best to use the longer end of the hex key, as the shorter end won't quite fit.
    • Repeat these steps on the other side of the motorcycle before continuing on to the next step.
  4. Kawasaki Ninja 300 Seat Replacement: étape 4, image 1 de 3 Kawasaki Ninja 300 Seat Replacement: étape 4, image 2 de 3 Kawasaki Ninja 300 Seat Replacement: étape 4, image 3 de 3
    • Grab the front section of the seat and slightly lift it up and back to remove it.
3 autres ont terminé cette réparation.
Craig Lloyd
Membre depuis le 02/10/16
36 293 Réputation
82 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 4
7 derniers jours : 37
30 derniers jours : 157
Total : 12,759
