Introduction
Utilisez ce tutoriel pour remplacer la courroie d'entraînement usée d'un lave-linge Kenmore Series 110.
Ce dont vous avez besoin
En utilisant une douille de 12,5 mm (1/2"), retirez le boulon qui fixe la poulie de tambour.
Retirez la poulie de tambour ainsi que la courroie.
I have difficulty to remove the bolt suring the pulley. Is there any tricky to move the bolt?
need to remove shaft off pulley
Thank you for the help .
what is the shaft? we can't get our on either
How can I Kno if it's the motor coupler or belt? Around the coupler is white plastic shavings.
The new belt is rigid and we're unable to stretch around the larger wheel. Any tricks?
Pour remonter votre appareil, suivez ces instructions dans l'ordre inverse.
18 autres ont terminé cette réparation.
Merci à ces traducteurs :
100%
Ces traducteurs nous aident réparer le monde ! Vous voulez contribuer ?
Commencez à traduire ›
8 commentaires
What would be reason that rinse cycle doesn't spin and it leaks
Will the drive belt make a clicking/grinding noise? I originally thought it was just a slipping noise, but empty it does make the grinding noise.
It makes noise like it’s working but it’s not grabbing anything
You can change your gearbox
What belt type should I use for a 110.24642300? I cannot find its belt online.
I have a Kenmore washer model # 110.16852500 I need the belt for this washer please it gives me everything but the belt
یک وبسایت تخصصی توی بحث تعمیرات ماشین لباسشویی در مشهد سایت مشهد تعمیر هستش که نمایندگی رسمی بیشتر از ۳۰ برند مانند سامسونگ الجی دوو بوش اسنوا ایندزیت و... هستش
How to tell if it's belt or coupler? I have white plastic shavings around it.
