Introduction
Utilisez ce tutoriel pour remplacer un pressostat défectueux.
Ce dont vous avez besoin
A l'aide d'une clé à douille de 8 mm (5/16") ou d'une clé à molette, retirez les trois vis de la partie arrière supérieure du lave-linge.
En le soulevant par l'arrière, retirez le couvercle.
Pour remonter votre appareil, suivez ces instructions dans l'ordre inverse.
5 autres ont terminé cette réparation.
Merci à ces traducteurs :
100%
Ces traducteurs nous aident réparer le monde ! Vous voulez contribuer ?
Commencez à traduire ›
4 commentaires
how to test water level switch??
What is the water sensor part # for a Kenmore model #11029842990?
Who has that part 4the best price?
Hi,
I replaced the water-level pressure switch with a new kit but it did not resolve my problem. After installing the switch and line, I selected the lowest level but the tub continued to fill beyond the smallest wash level. I have a Kenmore Model # 110.20902. What other part or solution could resolve my issue?
BTW: I read replacing the water inlet valve night be involved but I already did that within the last six months and everything worked fine until I noticed the water level had changed the last two washes to a large load only. In fact, the water looked above the large level during my last wash.
I would appreciate any insight.
Shannon
