Aller au contenu principal
Kindle Paperwhite 2nd Generation Motherboard Replacement
Ce dont vous avez besoin
  1. Kindle Paperwhite 2nd Generation Motherboard Replacement, Battery: étape 1, image 1 de 2 Kindle Paperwhite 2nd Generation Motherboard Replacement, Battery: étape 1, image 2 de 2
    • Insert plastic opening tool into the corners of the Paperwhite and slide around the edge perimeter to remove bezel.
    • Be sure to begin prying along the outer edges , these are the optimal points for removing the bezel.
    • Be careful and do not slide prying tool deeper than 3-4 mm under the side bezel or you could peel off screen protector film.
  2. Kindle Paperwhite 2nd Generation Motherboard Replacement: étape 2, image 1 de 2 Kindle Paperwhite 2nd Generation Motherboard Replacement: étape 2, image 2 de 2
    • Using a Screw Driver, Remove the eleven 3.2 mm Phillips 000 screws from corners of the mid-frame and from behind the black strip as shown.
    • Do not forget the screw in the middle of the black adhesive strip.
  3. Kindle Paperwhite 2nd Generation Motherboard Replacement: étape 3, image 1 de 1
    • Carefully remove the mid-frame from the back cover.
  4. Kindle Paperwhite 2nd Generation Motherboard Replacement: étape 4, image 1 de 2 Kindle Paperwhite 2nd Generation Motherboard Replacement: étape 4, image 2 de 2
    • Use a screwdriver to remove the three 3.0 mm Phillips 000 screws that are holding the battery in place as shown.
  5. Kindle Paperwhite 2nd Generation Motherboard Replacement: étape 5, image 1 de 1
    • Carefully lift the battery and remove it from the device.
  6. Kindle Paperwhite 2nd Generation Motherboard Replacement, Motherboard: étape 6, image 1 de 2 Kindle Paperwhite 2nd Generation Motherboard Replacement, Motherboard: étape 6, image 2 de 2
    • Use a screwdriver to remove the seven 3.0 mm Phillips 000 screws that are holding the motherboard in place as shown.
    • Don't lose the washer that is highlighted with an orange marker as shown. It is a necessary component to protect the screw.
  7. Kindle Paperwhite 2nd Generation Motherboard Replacement: étape 7, image 1 de 2 Kindle Paperwhite 2nd Generation Motherboard Replacement: étape 7, image 2 de 2
    • Gently disconnect the zif connectors.
    • Some of these connectors are very thin and fragile, handle with care!
  8. Kindle Paperwhite 2nd Generation Motherboard Replacement: étape 8, image 1 de 3 Kindle Paperwhite 2nd Generation Motherboard Replacement: étape 8, image 2 de 3 Kindle Paperwhite 2nd Generation Motherboard Replacement: étape 8, image 3 de 3
    • Gently remove the motherboard.
3 autres ont terminé cette réparation.
Tyler Davis
Membre depuis le 09/15/16
1 574 Réputation
5 tutoriels rédigés
Équipe
USF Tampa, Team 11-2, Blackwell Fall 2016 Membre de l'équipe USF Tampa, Team 11-2, Blackwell Fall 2016
USFT-BLACKWELL-F16S11G2
4 membres
7 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 31
Total : 3,313
