Introduction
This guide is meant to teach reader to install a new LCD screen. If the current LCD screen is broken or cracked LCD screen, this guide will help the reader to replace it with a new one.
Pièces
Aucune pièce nécessaire.
  1. Flip the camera over so the bottom is facing you.
    • Flip the camera over so the bottom is facing you.
  2. Open the cover on the bottom by sliding it in the direction of the arrow.
    • Open the cover on the bottom by sliding it in the direction of the arrow.
    • Remove the batteries by pulling up on the top with your fingers.
    • Unless otherwise stated, use a phillips #00 screwdriver to remove screws.
    • Remove the two 4.70mm screws in the bottom of the plastic casing.
    • Remove the four 4.70mm screws in the left side of the camera.
    • Now on the side with the strap, remove the other four 4.70mm screws.
    • Use your thumbs to pry the case apart.
    • It is easiest to pry to case apart if your start at the bottom.
    • The case should come apart with minimal effort. If it doesn't, you can use a tool such as a Spudger or Plastic Opening tool.
    • This step requires a significant amount of force.
    • Pull the bottom half of the inner camera out of case about half an inch. This may be difficult and force is necessary.
    • While pulling the camera out of the case, note the small soft plastic cover on the side of the camera. This cover will detach from the rest of the device.
    • Once the bottom of the inner camera is pulled out about an inch and a half, pull the device out completely.
    • When completely removing the device from the case, use a firm grasp with your hands for stability and control.
    • Turn the camera so that the LCD screen is facing you.
    • If case is still on, remove it by following the Plastic Casing Installation Guide found in the previous steps.
    • You will not be able to complete this guide without removing the casing completely.
    • Remove the four 4.40mm screws that hold the LCD screen in place to the frame.
    • Allow the LCD screen to flip down. This will expose the electric strip connecting the screen to the camera.
    • Look for where the yellow electric strip is attached to the camera. There is a plastic grey bar and a white base holding this strip in place.
    • Push the grey bar away from the white base. This will release the yellow electric strip and free the LCD screen from the camera.
    • Unplug the connected red and white wires. They will come out with the small white casing.
    • Flip camera so that the lens is facing away from you. You should be looking at the LCD screen.
    • Remove bottom left LCD mounting frame screw.
    • Remove LCD screen from camera. Screen should come loose after screw is removed. Make sure electric strip comes out with screen.
Nick Oleskowicz
Membre depuis le 03/04/2012
263 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team 15-13, Forte Spring 2012 Membre de l'équipe Cal Poly, Team 15-13, Forte Spring 2012
CPSU-FORTE-S12S15G13
5 membres
5 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 2
Total : 1,838
