Aller au contenu principal
LG Front Load Washing Machine Dampers Replacement
Ce dont vous avez besoin
  1. LG Front Load Washing Machine Dampers Replacement, Safety Precautions: étape 1, image 1 de 2 LG Front Load Washing Machine Dampers Replacement, Safety Precautions: étape 1, image 2 de 2
    • Before you begin your repair, perform the following:
    • Turn off the main water supply
    • Unplug your washer
    • Disconnect all water connections at the rear of your washer
  2. LG Front Load Washing Machine Dampers Replacement, Unfasten the top panel: étape 2, image 1 de 3 LG Front Load Washing Machine Dampers Replacement, Unfasten the top panel: étape 2, image 2 de 3 LG Front Load Washing Machine Dampers Replacement, Unfasten the top panel: étape 2, image 3 de 3
    • Remove the screw(s) securing the top panel brackets to the back panel.
    • You don't need to remove the screws securing the brackets to the top panel.
  3. LG Front Load Washing Machine Dampers Replacement, Remove the top panel: étape 3, image 1 de 2 LG Front Load Washing Machine Dampers Replacement, Remove the top panel: étape 3, image 2 de 2
    • Slide the top panel towards the rear of the device to disconnect its clips.
  4. LG Front Load Washing Machine Dampers Replacement: étape 4, image 1 de 2 LG Front Load Washing Machine Dampers Replacement: étape 4, image 2 de 2
    • Tilt the top panel upward to completely disconnect it from the chassis.
    • Remove the top panel.
  5. LG Front Load Washing Machine Dampers Replacement, Remove the detergent drawer: étape 5, image 1 de 2 LG Front Load Washing Machine Dampers Replacement, Remove the detergent drawer: étape 5, image 2 de 2
    • Pull the detergent drawer away from the chassis as far as it will go.
  6. LG Front Load Washing Machine Dampers Replacement: étape 6, image 1 de 3 LG Front Load Washing Machine Dampers Replacement: étape 6, image 2 de 3 LG Front Load Washing Machine Dampers Replacement: étape 6, image 3 de 3
    • Press down on the "Push" button to disengage the clips securing the detergent drawer.
    • Pull the drawer out of its slot on the chassis and remove it.
  7. LG Front Load Washing Machine Dampers Replacement, Disconnect the control panel: étape 7, image 1 de 3 LG Front Load Washing Machine Dampers Replacement, Disconnect the control panel: étape 7, image 2 de 3 LG Front Load Washing Machine Dampers Replacement, Disconnect the control panel: étape 7, image 3 de 3
    • Disconnect the connectors attached to the control panel.
    • Always grip cables by their connectors and not the wires themselves.
  8. LG Front Load Washing Machine Dampers Replacement, Unfasten the control panel: étape 8, image 1 de 2 LG Front Load Washing Machine Dampers Replacement, Unfasten the control panel: étape 8, image 2 de 2
    • Remove the screw(s) securing the control panel to the top edge of the chassis.
  9. LG Front Load Washing Machine Dampers Replacement, Unfasten the detergent dispenser: étape 9, image 1 de 1
    • Remove the screw(s) securing the detergent dispenser.
  10. LG Front Load Washing Machine Dampers Replacement, Unclip the control panel: étape 10, image 1 de 3 LG Front Load Washing Machine Dampers Replacement, Unclip the control panel: étape 10, image 2 de 3 LG Front Load Washing Machine Dampers Replacement, Unclip the control panel: étape 10, image 3 de 3
    • Use a flathead screwdriver, or a pry tool, to unclip the control panel from the chassis.
  11. LG Front Load Washing Machine Dampers Replacement, Remove the control panel: étape 11, image 1 de 3 LG Front Load Washing Machine Dampers Replacement, Remove the control panel: étape 11, image 2 de 3 LG Front Load Washing Machine Dampers Replacement, Remove the control panel: étape 11, image 3 de 3
    • Remove the control panel, making sure to thread any cables through the chassis.
  12. LG Front Load Washing Machine Dampers Replacement, Open the door: étape 12, image 1 de 2 LG Front Load Washing Machine Dampers Replacement, Open the door: étape 12, image 2 de 2
    • Open the front door completely.
  13. LG Front Load Washing Machine Dampers Replacement, Remove the boot ring: étape 13, image 1 de 3 LG Front Load Washing Machine Dampers Replacement, Remove the boot ring: étape 13, image 2 de 3 LG Front Load Washing Machine Dampers Replacement, Remove the boot ring: étape 13, image 3 de 3
    • Use needle nose pliers to grip the spring end of the metal ring at the bottom of the rubber boot.
    • Pull the ring away from the chassis to separate it from the boot.
  14. LG Front Load Washing Machine Dampers Replacement: étape 14, image 1 de 3 LG Front Load Washing Machine Dampers Replacement: étape 14, image 2 de 3 LG Front Load Washing Machine Dampers Replacement: étape 14, image 3 de 3
    • Use your hand to completely pull the ring off the boot.
    • During reassembly, perform the following:
    • Insert one end of the ring into its groove along the boot's perimeter.
    • Use pliers to slowly stretch the ring around the boot's perimeter until it's completely nested in its groove.
    • Be sure the spring is centered at the bottom of the boot when you reinstall it.
    • This procedure will take significant force.
  15. LG Front Load Washing Machine Dampers Replacement, Disconnect the boot: étape 15, image 1 de 3 LG Front Load Washing Machine Dampers Replacement, Disconnect the boot: étape 15, image 2 de 3 LG Front Load Washing Machine Dampers Replacement, Disconnect the boot: étape 15, image 3 de 3
    • Use your fingers to pull the boot off its lip on the front panel.
  16. LG Front Load Washing Machine Dampers Replacement: étape 16, image 1 de 3 LG Front Load Washing Machine Dampers Replacement: étape 16, image 2 de 3 LG Front Load Washing Machine Dampers Replacement: étape 16, image 3 de 3
    • Slide your fingers around the lip of the boot until it's completely separated from the panel.
  17. LG Front Load Washing Machine Dampers Replacement, Remove the filter panel: étape 17, image 1 de 3 LG Front Load Washing Machine Dampers Replacement, Remove the filter panel: étape 17, image 2 de 3 LG Front Load Washing Machine Dampers Replacement, Remove the filter panel: étape 17, image 3 de 3
    • Open the filter panel at the bottom of the front panel.
    • Unclip the filter panel.
  18. LG Front Load Washing Machine Dampers Replacement, Drain the machine: étape 18, image 1 de 3 LG Front Load Washing Machine Dampers Replacement, Drain the machine: étape 18, image 2 de 3 LG Front Load Washing Machine Dampers Replacement, Drain the machine: étape 18, image 3 de 3
    • Generally, you should drain your machine when you are repairing the pumps or any hoses leading to or from them.
    • Place a bowl next to the machine.
    • Pull the drain filter hose out of its slot in the chassis enough to lay over the bowl.
    • Remove the plug at the end of the drain filter hose to release excess water into the bowl.
    • During reassembly, re-plug the drain filter hose and thread it back through its slot in the chassis.
  19. LG Front Load Washing Machine Dampers Replacement, Unfasten the filter trim: étape 19, image 1 de 1
    • Remove the screw(s) securing the filter trim.
  20. LG Front Load Washing Machine Dampers Replacement, Remove the filter trim: étape 20, image 1 de 2 LG Front Load Washing Machine Dampers Replacement, Remove the filter trim: étape 20, image 2 de 2
    • Pull the filter trim straight off the front panel to remove it.
  21. LG Front Load Washing Machine Dampers Replacement, Unfasten the lower front panel: étape 21, image 1 de 1
    • Remove the screw(s) securing the lower front panel.
  22. LG Front Load Washing Machine Dampers Replacement, Unfasten the door latch: étape 22, image 1 de 1
    • Remove the screw(s) securing the door latch.
  23. LG Front Load Washing Machine Dampers Replacement, Remove the door latch: étape 23, image 1 de 3 LG Front Load Washing Machine Dampers Replacement, Remove the door latch: étape 23, image 2 de 3 LG Front Load Washing Machine Dampers Replacement, Remove the door latch: étape 23, image 3 de 3
    • Pull the door latch through its slot in the chassis and let it hang on its wire.
  24. LG Front Load Washing Machine Dampers Replacement, Unfasten the front panel: étape 24, image 1 de 3 LG Front Load Washing Machine Dampers Replacement, Unfasten the front panel: étape 24, image 2 de 3 LG Front Load Washing Machine Dampers Replacement, Unfasten the front panel: étape 24, image 3 de 3
    • Hold the front panel against the chassis while performing this step to prevent it from falling.
    • Remove the screw(s) securing the front panel.
  25. LG Front Load Washing Machine Dampers Replacement, Remove the front panel: étape 25, image 1 de 3 LG Front Load Washing Machine Dampers Replacement, Remove the front panel: étape 25, image 2 de 3 LG Front Load Washing Machine Dampers Replacement, Remove the front panel: étape 25, image 3 de 3
    • Lift the front panel upward to separate it from its clips on the bottom of the chassis.
    • Pull the front panel away from the chassis to completely separate the front panel.
  26. LG Front Load Washing Machine Dampers Replacement: étape 26, image 1 de 1
    • Remove the front panel.
  27. LG Front Load Washing Machine Dampers Replacement, Unfasten the rear panel: étape 27, image 1 de 3 LG Front Load Washing Machine Dampers Replacement, Unfasten the rear panel: étape 27, image 2 de 3 LG Front Load Washing Machine Dampers Replacement, Unfasten the rear panel: étape 27, image 3 de 3
    • Remove the screw(s) securing the rear panel.
  28. LG Front Load Washing Machine Dampers Replacement, Remove the rear panel: étape 28, image 1 de 3 LG Front Load Washing Machine Dampers Replacement, Remove the rear panel: étape 28, image 2 de 3 LG Front Load Washing Machine Dampers Replacement, Remove the rear panel: étape 28, image 3 de 3
    • Unclip the rear panel from the chassis.
  29. LG Front Load Washing Machine Dampers Replacement: étape 29, image 1 de 1
    • Remove the rear panel.
  30. LG Front Load Washing Machine Dampers Replacement, Disconnect the plastic pins: étape 30, image 1 de 3 LG Front Load Washing Machine Dampers Replacement, Disconnect the plastic pins: étape 30, image 2 de 3 LG Front Load Washing Machine Dampers Replacement, Disconnect the plastic pins: étape 30, image 3 de 3
    • Depending on your repair, you might need to access the dampers from the rear, the front, or both ends of the device. Choose whichever method works best for you.
    • Use a flathead screwdriver to press down on the tab securing the plastic pin.
    • You can also used an appropriately-sized box wrench to compress the pins.
    • Use a hammer to tap the pin out of its hole, still making sure the tab is compressed.
    • Repeat this procedure until the pin is loose enough to be removed with your hands.
  31. LG Front Load Washing Machine Dampers Replacement, Remove the plastic pin: étape 31, image 1 de 2 LG Front Load Washing Machine Dampers Replacement, Remove the plastic pin: étape 31, image 2 de 2
    • Remove the plastic pin.
    • Repeat these two steps for the second pin on the damper.
    • If your replacement dampers don't come with new pins, apply silicone grease to the old pins during reassembly.
  32. LG Front Load Washing Machine Dampers Replacement, Remove the damper: étape 32, image 1 de 3 LG Front Load Washing Machine Dampers Replacement, Remove the damper: étape 32, image 2 de 3 LG Front Load Washing Machine Dampers Replacement, Remove the damper: étape 32, image 3 de 3
    • Slide the damper out of its slot in the chassis to disconnect it.
    • Remove the damper.
    • If you're having difficulty removing the damper, compress it to shorten its length.
    • Repeat the last two steps for each damper you want to replace.
Repair didn’t go as planned? Ask our Answers community for help.
Bill Gilbert
Membre depuis le 06/30/22
30 088 Réputation
213 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
136 membres
17 411 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 7
30 derniers jours : 50
Total : 667
