Aller au contenu principal
LG Front Load Washing Machine Door Latch Replacement
Ce dont vous avez besoin
  1. LG Front Load Washing Machine Door Latch Replacement, Safety Precautions: étape 1, image 1 de 2 LG Front Load Washing Machine Door Latch Replacement, Safety Precautions: étape 1, image 2 de 2
    • Before you begin your repair, perform the following:
    • Turn off the main water supply
    • Unplug your washer
    • Disconnect all water connections at the rear of your washer
  2. LG Front Load Washing Machine Door Latch Replacement, Open the door: étape 2, image 1 de 2 LG Front Load Washing Machine Door Latch Replacement, Open the door: étape 2, image 2 de 2
    • Open the front door completely.
  3. LG Front Load Washing Machine Door Latch Replacement, Remove the boot ring: étape 3, image 1 de 3 LG Front Load Washing Machine Door Latch Replacement, Remove the boot ring: étape 3, image 2 de 3 LG Front Load Washing Machine Door Latch Replacement, Remove the boot ring: étape 3, image 3 de 3
    • Use needle nose pliers to grip the spring end of the metal ring at the bottom of the rubber boot.
    • Pull the ring away from the chassis to separate it from the boot.
  4. LG Front Load Washing Machine Door Latch Replacement: étape 4, image 1 de 3 LG Front Load Washing Machine Door Latch Replacement: étape 4, image 2 de 3 LG Front Load Washing Machine Door Latch Replacement: étape 4, image 3 de 3
    • Use your hand to completely pull the ring off the boot.
    • During reassembly, perform the following:
    • Insert one end of the ring into its groove along the boot's perimeter.
    • Use pliers to slowly stretch the ring around the boot's perimeter until it's completely nested in its groove.
    • Be sure the spring is centered at the bottom of the boot when you reinstall it.
    • This procedure will take significant force.
  5. LG Front Load Washing Machine Door Latch Replacement, Disconnect the boot: étape 5, image 1 de 3 LG Front Load Washing Machine Door Latch Replacement, Disconnect the boot: étape 5, image 2 de 3 LG Front Load Washing Machine Door Latch Replacement, Disconnect the boot: étape 5, image 3 de 3
    • Use your fingers to pull the boot off its lip in the front panel.
  6. LG Front Load Washing Machine Door Latch Replacement: étape 6, image 1 de 3 LG Front Load Washing Machine Door Latch Replacement: étape 6, image 2 de 3 LG Front Load Washing Machine Door Latch Replacement: étape 6, image 3 de 3
    • Work your fingers around the boot's perimeter until it's completely separated from the panel.
  7. LG Front Load Washing Machine Door Latch Replacement: étape 7, image 1 de 2 LG Front Load Washing Machine Door Latch Replacement: étape 7, image 2 de 2
    • Use your hands to fold the boot into the drum.
  8. LG Front Load Washing Machine Door Latch Replacement, Unfasten the door latch: étape 8, image 1 de 1
    • Remove the screw(s) securing the door latch.
  9. LG Front Load Washing Machine Door Latch Replacement, Expose the door latch: étape 9, image 1 de 3 LG Front Load Washing Machine Door Latch Replacement, Expose the door latch: étape 9, image 2 de 3 LG Front Load Washing Machine Door Latch Replacement, Expose the door latch: étape 9, image 3 de 3
    • Reach between the boot and the chassis to grip the door latch.
    • Pull the door latch out of its slot in the chassis to expose it.
    • Don't try to fully remove the door latch yet. It's still connected to a cable harness.
  10. LG Front Load Washing Machine Door Latch Replacement, Remove the door latch: étape 10, image 1 de 2 LG Front Load Washing Machine Door Latch Replacement, Remove the door latch: étape 10, image 2 de 2
    • Disconnect the cable harness from the door latch.
    • Always grip cables by their connectors and not the wires themselves.
    • Remove the door latch.
Repair didn’t go as planned? Ask our Answers community for help.
Bill Gilbert
Membre depuis le 06/30/22
30 797 Réputation
213 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
140 membres
18 069 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 11
7 derniers jours : 54
30 derniers jours : 272
Total : 4,194
