Introduction
Use this guide to remove and replace the drain hose in your LG front load washing machine.
The drain hose channels wastewater out of the washer. It's a single piece of hose that's connected to the drain pump inside the washer. To replace it, you'll have to access the washer internals.
This guide will work for most LG front load washing machines. This guide is written with a model WM3050CW washer. If you have a different model, you may encounter some minor disassembly differences, but the overall repair process will be the same.
The metal ring holding the rubber boot can be difficult to reinstall. You can buy this tool to make the reinstallation easier, or ask additional people to help.
Ce dont vous avez besoin
Turn off the main water supply
Unplug your washer
Disconnect all water connections at the rear of your washer
Remove the screw(s) securing the top panel brackets to the back panel.
Slide the top panel towards the rear of the device to disconnect its clips.
Pull the detergent drawer away from the chassis as far as it will go.
Disconnect the connectors attached to the control panel.
Remove the screw(s) securing the control panel to the top edge of the chassis.
Remove the screw(s) securing the detergent dispenser.
Use a flathead screwdriver, or a pry tool, to unclip the control panel from the chassis.
Remove the control panel, making sure to thread any cables through the chassis.
Use needle nose pliers to grip the spring end of the metal ring at the bottom of the rubber boot.
Pull the ring away from the chassis to separate it from the boot.
Use your hand to completely pull the ring off the boot.
Insert one end of the ring into its groove along the boot's perimeter.
Use pliers to slowly stretch the ring around the boot's perimeter until it's completely nested in its groove.
Use your fingers to pull the boot off its lip on the front panel.
Open the filter panel at the bottom of the front panel.
Unclip the filter panel.
Place a bowl next to the machine.
Pull the drain filter hose out of its slot in the chassis enough to lay over the bowl.
Remove the plug at the end of the drain filter hose to release excess water into the bowl.
Pull the filter trim straight off the front panel to remove it.
Remove the screw(s) securing the lower front panel.
Pull the door latch through its slot in the chassis and let it hang on its wire.
Lift the front panel upward to separate it from its clips on the bottom of the chassis.
Pull the front panel away from the chassis to completely separate the front panel.
Use slip joint pliers to pinch the drain hose clamp and slide it up the hose away from the pump assembly.
While holding the back of clip with one hand, use the other to push the prongs of the clip and release them.
Repeat for each prong until the clip slides through the chassis.
Reposition the drain hose so you can access the plastic clip.
To prevent confusion during reassembly, apply some masking tape where the plastic clip is located.
Pull the plastic clip off the drain hose.
Remove the plastic clip.
Repair didn’t go as planned? Ask our Answers community for help.
7 commentaires de tutoriel
Hello! You need the water out, but you can try to drain it by lowering the drain hose to floor level with a pan or shallow bowl to catch water from the end of it. If your drain hose is the problem (like it is plugged or kinked), this probably won't work. A fast but messy way to drain the washer is to remove the coin trap/filter basket located at the front of the machine (see step 18 the large round black cap is what you remove). Have a lot of towels on hand to absorb the water. If you want to you can use the small drain hose that is next to the filter. Have a bowl or container on hand to catch the water. pull the small plug out from the end of the little hose and water will start draining. It will be slow but a lot less messy.
I just added a step to show how to drain the machine (it is a new Step 18 in the guide)
I just need to check the drain hose for a clog. Is there a way to disconnect the drain hose without disassembling the machine so much? or, can I disconnect the drain hose after removing the rear panel?
