Introduction
Use this guide to replace one or both inlet valve assemblies in your LG front load washing machine.
The inlet valves control the flow of hot and cold water into the washer. If your washer doesn't fill with water and your water supply is fine, you may need to replace these valves.
Note: this guide only shows replacing the cold water assembly. The hot water assembly is adjacent to the cold water, and the procedure is identical.
This guide will work for most LG front load washing machines. This guide is written with a model WM3050CW washer. If you have a different model, you may encounter some minor disassembly differences, but the overall repair process will be the same.
Ce dont vous avez besoin
Turn off the main water supply
Unplug your washer
Disconnect all water connections at the rear of your washer
Remove the screw(s) securing the top panel brackets to the back panel.
Slide the top panel towards the rear of the device to disconnect its clips.
To prevent confusion, label each valve and its corresponding hose.
Repeat the labelling procedure for each valve and its corresponding connector.
Use needle nose pliers to pull the inlet valve filters straight out of the inlets in the chassis.
Remove the filters.
Remove the screws securing the inlet valve assembly.
Pull the inlet valve assembly straight out of its slot in the chassis to remove it.
Repair didn’t go as planned? Ask our Answers community for help.
