Aller au contenu principal
LG Front Load Washing Machine Pump Assembly Replacement
Ce dont vous avez besoin
  1. LG Front Load Washing Machine Pump Assembly Replacement, Safety Precautions: étape 1, image 1 de 2 LG Front Load Washing Machine Pump Assembly Replacement, Safety Precautions: étape 1, image 2 de 2
    • Before you begin your repair, perform the following:
    • Turn off the main water supply
    • Unplug your washer
    • Disconnect all water connections at the rear of your washer
  2. LG Front Load Washing Machine Pump Assembly Replacement, Unfasten the top panel: étape 2, image 1 de 3 LG Front Load Washing Machine Pump Assembly Replacement, Unfasten the top panel: étape 2, image 2 de 3 LG Front Load Washing Machine Pump Assembly Replacement, Unfasten the top panel: étape 2, image 3 de 3
    • Remove the screw(s) securing the top panel brackets to the back panel.
    • You don't need to remove the screws securing the brackets to the top panel.
  3. LG Front Load Washing Machine Pump Assembly Replacement, Remove the top panel: étape 3, image 1 de 2 LG Front Load Washing Machine Pump Assembly Replacement, Remove the top panel: étape 3, image 2 de 2
    • Slide the top panel towards the rear of the device to disconnect its clips.
  4. LG Front Load Washing Machine Pump Assembly Replacement: étape 4, image 1 de 2 LG Front Load Washing Machine Pump Assembly Replacement: étape 4, image 2 de 2
    • Tilt the top panel upward to completely disconnect it from the chassis.
    • Remove the top panel.
  5. LG Front Load Washing Machine Pump Assembly Replacement, Remove the detergent drawer: étape 5, image 1 de 2 LG Front Load Washing Machine Pump Assembly Replacement, Remove the detergent drawer: étape 5, image 2 de 2
    • Pull the detergent drawer away from the chassis as far as it will go.
  6. LG Front Load Washing Machine Pump Assembly Replacement: étape 6, image 1 de 3 LG Front Load Washing Machine Pump Assembly Replacement: étape 6, image 2 de 3 LG Front Load Washing Machine Pump Assembly Replacement: étape 6, image 3 de 3
    • Press down on the "Push" button to disengage the clips securing the detergent drawer.
    • Pull the drawer out of its slot on the chassis and remove it.
  7. LG Front Load Washing Machine Pump Assembly Replacement, Disconnect the control panel: étape 7, image 1 de 3 LG Front Load Washing Machine Pump Assembly Replacement, Disconnect the control panel: étape 7, image 2 de 3 LG Front Load Washing Machine Pump Assembly Replacement, Disconnect the control panel: étape 7, image 3 de 3
    • Disconnect the connectors attached to the control panel.
    • Always grip cables by their connectors and not the wires themselves.
  8. LG Front Load Washing Machine Pump Assembly Replacement, Unfasten the control panel: étape 8, image 1 de 2 LG Front Load Washing Machine Pump Assembly Replacement, Unfasten the control panel: étape 8, image 2 de 2
    • Remove the screw(s) securing the control panel to the top edge of the chassis.
  9. LG Front Load Washing Machine Pump Assembly Replacement, Unfasten the detergent dispenser: étape 9, image 1 de 1
    • Remove the screw(s) securing the detergent dispenser.
  10. LG Front Load Washing Machine Pump Assembly Replacement, Unclip the control panel: étape 10, image 1 de 3 LG Front Load Washing Machine Pump Assembly Replacement, Unclip the control panel: étape 10, image 2 de 3 LG Front Load Washing Machine Pump Assembly Replacement, Unclip the control panel: étape 10, image 3 de 3
    • Use a flathead screwdriver, or a pry tool, to unclip the control panel from the chassis.
  11. LG Front Load Washing Machine Pump Assembly Replacement, Remove the control panel: étape 11, image 1 de 3 LG Front Load Washing Machine Pump Assembly Replacement, Remove the control panel: étape 11, image 2 de 3 LG Front Load Washing Machine Pump Assembly Replacement, Remove the control panel: étape 11, image 3 de 3
    • Remove the control panel, making sure to thread any cables through the chassis.
  12. LG Front Load Washing Machine Pump Assembly Replacement, Open the door: étape 12, image 1 de 2 LG Front Load Washing Machine Pump Assembly Replacement, Open the door: étape 12, image 2 de 2
    • Open the front door completely.
  13. LG Front Load Washing Machine Pump Assembly Replacement, Remove the boot ring: étape 13, image 1 de 3 LG Front Load Washing Machine Pump Assembly Replacement, Remove the boot ring: étape 13, image 2 de 3 LG Front Load Washing Machine Pump Assembly Replacement, Remove the boot ring: étape 13, image 3 de 3
    • Use needle nose pliers to grip the spring end of the metal ring at the bottom of the rubber boot.
    • Pull the ring away from the chassis to separate it from the boot.
  14. LG Front Load Washing Machine Pump Assembly Replacement: étape 14, image 1 de 3 LG Front Load Washing Machine Pump Assembly Replacement: étape 14, image 2 de 3 LG Front Load Washing Machine Pump Assembly Replacement: étape 14, image 3 de 3
    • Use your hand to completely pull the ring off the boot.
    • During reassembly, perform the following:
    • Insert one end of the ring into its groove along the boot's perimeter.
    • Use pliers to slowly stretch the ring around the boot's perimeter until it's completely nested in its groove.
    • Be sure the spring is centered at the bottom of the boot when you reinstall it.
    • This procedure will take significant force.
  15. LG Front Load Washing Machine Pump Assembly Replacement, Disconnect the boot: étape 15, image 1 de 3 LG Front Load Washing Machine Pump Assembly Replacement, Disconnect the boot: étape 15, image 2 de 3 LG Front Load Washing Machine Pump Assembly Replacement, Disconnect the boot: étape 15, image 3 de 3
    • Use your fingers to pull the boot off its lip on the front panel.
  16. LG Front Load Washing Machine Pump Assembly Replacement: étape 16, image 1 de 3 LG Front Load Washing Machine Pump Assembly Replacement: étape 16, image 2 de 3 LG Front Load Washing Machine Pump Assembly Replacement: étape 16, image 3 de 3
    • Slide your fingers around the lip of the boot until it's completely separated from the panel.
  17. LG Front Load Washing Machine Pump Assembly Replacement, Remove the filter panel: étape 17, image 1 de 3 LG Front Load Washing Machine Pump Assembly Replacement, Remove the filter panel: étape 17, image 2 de 3 LG Front Load Washing Machine Pump Assembly Replacement, Remove the filter panel: étape 17, image 3 de 3
    • Open the filter panel at the bottom of the front panel.
    • Unclip the filter panel.
  18. LG Front Load Washing Machine Pump Assembly Replacement, Drain the machine: étape 18, image 1 de 3 LG Front Load Washing Machine Pump Assembly Replacement, Drain the machine: étape 18, image 2 de 3 LG Front Load Washing Machine Pump Assembly Replacement, Drain the machine: étape 18, image 3 de 3
    • Generally, you should drain your machine when you are repairing the pumps or any hoses leading to or from them.
    • Place a bowl next to the machine.
    • Pull the drain filter hose out of its slot in the chassis enough to lay over the bowl.
    • Remove the plug at the end of the drain filter hose to release excess water into the bowl.
    • During reassembly, re-plug the drain filter hose and thread it back through its slot in the chassis.
  19. LG Front Load Washing Machine Pump Assembly Replacement, Unfasten the filter trim: étape 19, image 1 de 1
    • Remove the screw(s) securing the filter trim.
  20. LG Front Load Washing Machine Pump Assembly Replacement, Remove the filter trim: étape 20, image 1 de 2 LG Front Load Washing Machine Pump Assembly Replacement, Remove the filter trim: étape 20, image 2 de 2
    • Pull the filter trim straight off the front panel to remove it.
  21. LG Front Load Washing Machine Pump Assembly Replacement, Unfasten the lower front panel: étape 21, image 1 de 1
    • Remove the screw(s) securing the lower front panel.
  22. LG Front Load Washing Machine Pump Assembly Replacement, Unfasten the door latch: étape 22, image 1 de 1
    • Remove the screw(s) securing the door latch.
  23. LG Front Load Washing Machine Pump Assembly Replacement, Remove the door latch: étape 23, image 1 de 3 LG Front Load Washing Machine Pump Assembly Replacement, Remove the door latch: étape 23, image 2 de 3 LG Front Load Washing Machine Pump Assembly Replacement, Remove the door latch: étape 23, image 3 de 3
    • Pull the door latch through its slot in the chassis and let it hang on its wire.
  24. LG Front Load Washing Machine Pump Assembly Replacement, Unfasten the front panel: étape 24, image 1 de 3 LG Front Load Washing Machine Pump Assembly Replacement, Unfasten the front panel: étape 24, image 2 de 3 LG Front Load Washing Machine Pump Assembly Replacement, Unfasten the front panel: étape 24, image 3 de 3
    • Hold the front panel against the chassis while performing this step to prevent it from falling.
    • Remove the screw(s) securing the front panel.
  25. LG Front Load Washing Machine Pump Assembly Replacement, Remove the front panel: étape 25, image 1 de 3 LG Front Load Washing Machine Pump Assembly Replacement, Remove the front panel: étape 25, image 2 de 3 LG Front Load Washing Machine Pump Assembly Replacement, Remove the front panel: étape 25, image 3 de 3
    • Lift the front panel upward to separate it from its clips on the bottom of the chassis.
    • Pull the front panel away from the chassis to completely separate the front panel.
  26. LG Front Load Washing Machine Pump Assembly Replacement: étape 26, image 1 de 1
    • Remove the front panel.
  27. LG Front Load Washing Machine Pump Assembly Replacement, Remove the pump filter: étape 27, image 1 de 3 LG Front Load Washing Machine Pump Assembly Replacement, Remove the pump filter: étape 27, image 2 de 3 LG Front Load Washing Machine Pump Assembly Replacement, Remove the pump filter: étape 27, image 3 de 3
    • Twist and remove the pump filter.
  28. LG Front Load Washing Machine Pump Assembly Replacement, Reposition the drain hose: étape 28, image 1 de 3 LG Front Load Washing Machine Pump Assembly Replacement, Reposition the drain hose: étape 28, image 2 de 3 LG Front Load Washing Machine Pump Assembly Replacement, Reposition the drain hose: étape 28, image 3 de 3
    • Push the drain hose through its hole in the chassis until it's completely inside the device.
  29. LG Front Load Washing Machine Pump Assembly Replacement, Unwrap the pump assembly cables: étape 29, image 1 de 3 LG Front Load Washing Machine Pump Assembly Replacement, Unwrap the pump assembly cables: étape 29, image 2 de 3 LG Front Load Washing Machine Pump Assembly Replacement, Unwrap the pump assembly cables: étape 29, image 3 de 3
    • Use diagonal cutters, or scissors, to remove any cable ties securing the plastic wrap on the pump assembly cable connector(s).
  30. LG Front Load Washing Machine Pump Assembly Replacement: étape 30, image 1 de 2 LG Front Load Washing Machine Pump Assembly Replacement: étape 30, image 2 de 2
    • Fold the plastic wrap away from the cables, enough to expose the connector(s).
    • During reassembly, replace the cable ties to ensure a water-tight fit for the plastic wrap.
  31. LG Front Load Washing Machine Pump Assembly Replacement, Disconnect the pump cable: étape 31, image 1 de 2 LG Front Load Washing Machine Pump Assembly Replacement, Disconnect the pump cable: étape 31, image 2 de 2
    • Disconnect the connector(s) attached to the pump cable.
  32. LG Front Load Washing Machine Pump Assembly Replacement, Disconnect the drain hose: étape 32, image 1 de 3 LG Front Load Washing Machine Pump Assembly Replacement, Disconnect the drain hose: étape 32, image 2 de 3 LG Front Load Washing Machine Pump Assembly Replacement, Disconnect the drain hose: étape 32, image 3 de 3
    • Use slip joint pliers to pinch the drain hose clamp and slide it up the hose away from the pump assembly.
  33. LG Front Load Washing Machine Pump Assembly Replacement: étape 33, image 1 de 3 LG Front Load Washing Machine Pump Assembly Replacement: étape 33, image 2 de 3 LG Front Load Washing Machine Pump Assembly Replacement: étape 33, image 3 de 3
    • Use slip joint pliers to rotate the drain hose back and forth around its connection and loosen it.
    • Pull the drain hose straight off its connection on the assembly.
  34. LG Front Load Washing Machine Pump Assembly Replacement, Disconnect the pump hose: étape 34, image 1 de 3 LG Front Load Washing Machine Pump Assembly Replacement, Disconnect the pump hose: étape 34, image 2 de 3 LG Front Load Washing Machine Pump Assembly Replacement, Disconnect the pump hose: étape 34, image 3 de 3
    • Repeat the last two steps for the pump hose.
  35. LG Front Load Washing Machine Pump Assembly Replacement, Unfasten the pump assembly: étape 35, image 1 de 2 LG Front Load Washing Machine Pump Assembly Replacement, Unfasten the pump assembly: étape 35, image 2 de 2
    • Remove the screw(s) securing the pump assembly to the bottom lip of the washer.
  36. LG Front Load Washing Machine Pump Assembly Replacement, Remove the pump assembly: étape 36, image 1 de 3 LG Front Load Washing Machine Pump Assembly Replacement, Remove the pump assembly: étape 36, image 2 de 3 LG Front Load Washing Machine Pump Assembly Replacement, Remove the pump assembly: étape 36, image 3 de 3
    • Lift the pump assembly out of its location in the frame to remove it.
Repair didn’t go as planned? Ask our Answers community for help.
Bill Gilbert
Membre depuis le 06/30/22
30 088 Réputation
213 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
136 membres
17 430 tutoriels rédigés
Un commentaire
Hi Bill, Fantastic instructions - thanks for taking the time to put these together!
Ken Adams - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 5
7 derniers jours : 47
30 derniers jours : 138
Total : 984
