Aller au contenu principal
LG Front Load Washing Machine Rotor Replacement
Ce dont vous avez besoin
  1. LG Front Load Washing Machine Rotor Replacement, Safety Precautions: étape 1, image 1 de 2 LG Front Load Washing Machine Rotor Replacement, Safety Precautions: étape 1, image 2 de 2
    • Before you begin your repair, perform the following:
    • Turn off the main water supply
    • Unplug your washer
    • Disconnect all water connections at the rear of your washer
  2. LG Front Load Washing Machine Rotor Replacement, Unfasten the rear panel: étape 2, image 1 de 3 LG Front Load Washing Machine Rotor Replacement, Unfasten the rear panel: étape 2, image 2 de 3 LG Front Load Washing Machine Rotor Replacement, Unfasten the rear panel: étape 2, image 3 de 3
    • Remove the screw(s) securing the rear panel.
  3. LG Front Load Washing Machine Rotor Replacement, Remove the rear panel: étape 3, image 1 de 3 LG Front Load Washing Machine Rotor Replacement, Remove the rear panel: étape 3, image 2 de 3 LG Front Load Washing Machine Rotor Replacement, Remove the rear panel: étape 3, image 3 de 3
    • Unclip the rear panel from the chassis.
  4. LG Front Load Washing Machine Rotor Replacement: étape 4, image 1 de 1
    • Remove the rear panel.
  5. LG Front Load Washing Machine Rotor Replacement, Unfasten the rotor: étape 5, image 1 de 2 LG Front Load Washing Machine Rotor Replacement, Unfasten the rotor: étape 5, image 2 de 2
    • Use an impact driver to remove the 17 mm nut securing the rotor.
    • Alternatively, you can use a wrench and a hammer to loosen the nut.
    • To secure the rotor, you can insert a screwdriver, or a similar tool, between the rotor and the stator. Make sure to brace the tool against one of the screw bosses on the stator.
  6. LG Front Load Washing Machine Rotor Replacement, Remove the rotor: étape 6, image 1 de 2 LG Front Load Washing Machine Rotor Replacement, Remove the rotor: étape 6, image 2 de 2
    • The rotor is magnetically attracted to the stator.
    • Pull the rotor straight off the stator and drive shaft splines to remove it.
    • Wiggle the rotor as you pull to help disconnect it.
    • This may require significant force.
    • During reassembly, watch your fingers when aligning the rotor over the stator, as the rotor gets sucked in easily.
Repair didn’t go as planned? Ask our Answers community for help.
Bill Gilbert
Membre depuis le 06/30/22
30 088 Réputation
213 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
136 membres
17 430 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 8
30 derniers jours : 39
Total : 729
