Aller au contenu principal
LG G8 ThinQ Headphone Jack Replacement
Ce dont vous avez besoin
  1. LG G8 ThinQ Headphone Jack Replacement, SIM Card Tray: étape 1, image 1 de 3 LG G8 ThinQ Headphone Jack Replacement, SIM Card Tray: étape 1, image 2 de 3 LG G8 ThinQ Headphone Jack Replacement, SIM Card Tray: étape 1, image 3 de 3
    • Unplug and power off your phone before you begin.
    • Insert the SIM card eject tool into the pinhole in the lower right side of the phone.
    • Remove the SIM card and tray.
  2. LG G8 ThinQ Headphone Jack Replacement, Back Panel: étape 2, image 1 de 3 LG G8 ThinQ Headphone Jack Replacement, Back Panel: étape 2, image 2 de 3 LG G8 ThinQ Headphone Jack Replacement, Back Panel: étape 2, image 3 de 3
    • Place the phone so that the screen is facing down.
    • Insert opening cards between the back panel and frame of the phone to loosen the clips and adhesive.
    • Using equal pressure, carefully pry the back panel away from the phone.
    • Once enough space has been created, use an opening tool to completely separate the back panel from the phone.
  3. LG G8 ThinQ Headphone Jack Replacement, Midframe: étape 3, image 1 de 3 LG G8 ThinQ Headphone Jack Replacement, Midframe: étape 3, image 2 de 3 LG G8 ThinQ Headphone Jack Replacement, Midframe: étape 3, image 3 de 3
    • Remove all 14 screws from the midframe using a Phillips #000 screwdriver.
    • Work an opening tool around the perimeter of the midframe to pry and remove it from the phone.
  4. LG G8 ThinQ Headphone Jack Replacement, Speaker System: étape 4, image 1 de 3 LG G8 ThinQ Headphone Jack Replacement, Speaker System: étape 4, image 2 de 3 LG G8 ThinQ Headphone Jack Replacement, Speaker System: étape 4, image 3 de 3
    • Using an opening tool, carefully pry out remove the speaker system from the phone.
  5. LG G8 ThinQ Headphone Jack Replacement, Headphone Jack: étape 5, image 1 de 3 LG G8 ThinQ Headphone Jack Replacement, Headphone Jack: étape 5, image 2 de 3 LG G8 ThinQ Headphone Jack Replacement, Headphone Jack: étape 5, image 3 de 3
    • Using an opening tool, carefully disconnect the ribbon cable connecting the 3.5mm audio jack to the motherboard.
    • Remove the screw holding the 3.5 mm audio jack in place using a Phillips #000 screwdriver.
    • Remove the audio jack from the phone.
Hunter Johnson
Membre depuis le 09/17/21
227 Réputation
2 tutoriels rédigés
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 14
Total : 1,170
