Aller au contenu principal
LG V50 ThinQ Battery Replacement
Ce dont vous avez besoin
  1. LG V50 ThinQ Battery Replacement, Battery: étape 1, image 1 de 3 LG V50 ThinQ Battery Replacement, Battery: étape 1, image 2 de 3 LG V50 ThinQ Battery Replacement, Battery: étape 1, image 3 de 3
    • Flip the phone over, so that the back of the phone is facing you.
    • Using an opening pick, pry open the back cover of the phone by moving the opening pick along all sides to reveal the internal components.
  2. LG V50 ThinQ Battery Replacement: étape 2, image 1 de 3 LG V50 ThinQ Battery Replacement: étape 2, image 2 de 3 LG V50 ThinQ Battery Replacement: étape 2, image 3 de 3
    • Remove all twelve 1 mm Phillips #000 screws.
    • Remember to keep the screws in a safe place for reassembly later!
  3. LG V50 ThinQ Battery Replacement: étape 3, image 1 de 3 LG V50 ThinQ Battery Replacement: étape 3, image 2 de 3 LG V50 ThinQ Battery Replacement: étape 3, image 3 de 3
    • Remove the two brackets.
  4. LG V50 ThinQ Battery Replacement: étape 4, image 1 de 2 LG V50 ThinQ Battery Replacement: étape 4, image 2 de 2
    • DO NOT attempt to remove the phone battery with a metallic/sharp prying object.
    • Disconnect the battery from the phone by removing the battery connection from the connector port.
    • Remove the battery by prying the underside of the battery and pulling upwards with the opening pick (shown in image 2).
    • Do not be too rough with the battery, as it is easy to dent/break into.
    • Now, place the new battery inside the slot, firmly pressing it into the space against the copper-colored heatsink on the bottom.
3 autres ont terminé cette réparation.
Tanmay Sonawane
Membre depuis le 10/30/23
262 Réputation
2 tutoriels rédigés
Équipe
UMass Dartmouth, Team 2-3, Gulbrandsen Fall 2023 Membre de l'équipe UMass Dartmouth, Team 2-3, Gulbrandsen Fall 2023
UMASSD-GULBRANDSEN-F23S2G3
4 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 23
30 derniers jours : 76
Total : 1,360
