Aller au contenu principal
LG V50 ThinQ Motherboard Replacement
Ce dont vous avez besoin
  1. LG V50 ThinQ Motherboard Replacement, Motherboard: étape 1, image 1 de 3 LG V50 ThinQ Motherboard Replacement, Motherboard: étape 1, image 2 de 3 LG V50 ThinQ Motherboard Replacement, Motherboard: étape 1, image 3 de 3
    • Flip the phone over, so that the back of the phone is facing you.
    • Using an opening pick, pry open the back cover of the phone by moving the opening pick along all sides to reveal the internal components.
  2. LG V50 ThinQ Motherboard Replacement: étape 2, image 1 de 3 LG V50 ThinQ Motherboard Replacement: étape 2, image 2 de 3 LG V50 ThinQ Motherboard Replacement: étape 2, image 3 de 3
    • With the back side open, unscrew all the 1 mm Phillips #000 screws.
    • Remember to keep the screws in a safe place for reassembly later!
  3. LG V50 ThinQ Motherboard Replacement: étape 3, image 1 de 3 LG V50 ThinQ Motherboard Replacement: étape 3, image 2 de 3 LG V50 ThinQ Motherboard Replacement: étape 3, image 3 de 3
    • Take out the two brackets that are covering the internal components.
  4. LG V50 ThinQ Motherboard Replacement: étape 4, image 1 de 3 LG V50 ThinQ Motherboard Replacement: étape 4, image 2 de 3 LG V50 ThinQ Motherboard Replacement: étape 4, image 3 de 3
    Outil utilisé dans cette étape :
    • Remove the battery connection from its connector port, located above the battery.
    • Similarly, remove the screen connection from its connector port, found on the left side of the back of the device.
    • Pull up with tweezers on the dark orange cable to disconnect it.
  5. LG V50 ThinQ Motherboard Replacement: étape 5, image 1 de 3 LG V50 ThinQ Motherboard Replacement: étape 5, image 2 de 3 LG V50 ThinQ Motherboard Replacement: étape 5, image 3 de 3
    • Disconnect the orange cable by pulling the connector piece up with your fingers
    • Pull up with tweezers on the end of the white wire to disconnect it from the motherboard
    • Using the metal spudger, pull up from below the motherboard at the top of the phone and near the battery to remove the motherboard from the phone.
Tanmay Sonawane
Membre depuis le 10/30/23
271 Réputation
2 tutoriels rédigés
Équipe
UMass Dartmouth, Team 2-3, Gulbrandsen Fall 2023 Membre de l'équipe UMass Dartmouth, Team 2-3, Gulbrandsen Fall 2023
UMASSD-GULBRANDSEN-F23S2G3
4 membres
5 tutoriels rédigés
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 26
Total : 449
