Aller au contenu principal
LG V50 ThinQ Speaker & Charging Port Replacement
Ce dont vous avez besoin
  1. LG V50 ThinQ Speaker & Charging Port Replacement, Speaker System / Charger Port: étape 1, image 1 de 3 LG V50 ThinQ Speaker & Charging Port Replacement, Speaker System / Charger Port: étape 1, image 2 de 3 LG V50 ThinQ Speaker & Charging Port Replacement, Speaker System / Charger Port: étape 1, image 3 de 3
    • Flip the phone over, so that the back of the phone is facing you.
    • Using an opening pick, pry open the back cover of the phone by moving the opening pick along all sides to reveal the internal components.
  2. LG V50 ThinQ Speaker & Charging Port Replacement: étape 2, image 1 de 3 LG V50 ThinQ Speaker & Charging Port Replacement: étape 2, image 2 de 3 LG V50 ThinQ Speaker & Charging Port Replacement: étape 2, image 3 de 3
    • With the back side open, remove all 12 1 mm Phillips #000 screws.
    • Remember to keep the screws in a safe place for reassembly later!
  3. LG V50 ThinQ Speaker & Charging Port Replacement: étape 3, image 1 de 3 LG V50 ThinQ Speaker & Charging Port Replacement: étape 3, image 2 de 3 LG V50 ThinQ Speaker & Charging Port Replacement: étape 3, image 3 de 3
    • Remove the two brackets that are covering internal components.
  4. LG V50 ThinQ Speaker & Charging Port Replacement: étape 4, image 1 de 3 LG V50 ThinQ Speaker & Charging Port Replacement: étape 4, image 2 de 3 LG V50 ThinQ Speaker & Charging Port Replacement: étape 4, image 3 de 3
    Outil utilisé dans cette étape :
    • Disconnect the battery from the phone by removing the battery connection from the connector port.
    • Disconnect the orange cable by pulling the connector up with your fingers.
    • Pull up with tweezers on the end of the white wire to disconnect it from the two circuit boards.
    • Pull up with tweezers on the dark orange cable to disconnect it.
  5. LG V50 ThinQ Speaker & Charging Port Replacement: étape 5, image 1 de 3 LG V50 ThinQ Speaker & Charging Port Replacement: étape 5, image 2 de 3 LG V50 ThinQ Speaker & Charging Port Replacement: étape 5, image 3 de 3
    • Take out the SIM card by using the SIM head and pushing into the SIM ejector slot.
    • Disconnect the orange panel nearby the SIM slot from the circuit board.
    • Pull up from below the circuit board on the top, next to the CMOS battery to remove the upper circuiting from the phone.
  6. LG V50 ThinQ Speaker & Charging Port Replacement: étape 6, image 1 de 3 LG V50 ThinQ Speaker & Charging Port Replacement: étape 6, image 2 de 3 LG V50 ThinQ Speaker & Charging Port Replacement: étape 6, image 3 de 3
    • Pull up from the right of the metallic cover piece inside of the bottom right of the phone.
    • Remove the metallic piece's base from the board.
    • Make the cubic piece moveable by wiggling under it with an opening pick or spudger.
  7. LG V50 ThinQ Speaker & Charging Port Replacement: étape 7, image 1 de 1
    • Remove bottom circuiting, the speaker system is a part of the bottom circuit board.
William Martin
Membre depuis le 11/01/23
231 Réputation
1 tutoriel rédigé
Équipe
UMass Dartmouth, Team 2-3, Gulbrandsen Fall 2023 Membre de l'équipe UMass Dartmouth, Team 2-3, Gulbrandsen Fall 2023
UMASSD-GULBRANDSEN-F23S2G3
4 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 7
Total : 325
