Aller au contenu principal
LG VX5200 LCD Screen Replacement
Ce dont vous avez besoin
  1. LG VX5200 LCD Screen Replacement, Battery: étape 1, image 1 de 2 LG VX5200 LCD Screen Replacement, Battery: étape 1, image 2 de 2
    • Turn the phone on its back.
  2. LG VX5200 LCD Screen Replacement: étape 2, image 1 de 2 LG VX5200 LCD Screen Replacement: étape 2, image 2 de 2
    • Orient the phone as shown.
    • Remove the battery cover by pushing upward with your thumb.
  3. LG VX5200 LCD Screen Replacement: étape 3, image 1 de 2 LG VX5200 LCD Screen Replacement: étape 3, image 2 de 2
    • Place your fingernail at the top of the battery and pry the battery out towards you.
  4. LG VX5200 LCD Screen Replacement, Face Plate: étape 4, image 1 de 3 LG VX5200 LCD Screen Replacement, Face Plate: étape 4, image 2 de 3 LG VX5200 LCD Screen Replacement, Face Plate: étape 4, image 3 de 3
    • Flip the phone open.
    • Remove the four rubber plugs, located at the corners of the LCD screen, with a push-pin.
    • Use a Phillips #00 screwdriver to remove the four screws located underneath the rubber plugs.
  5. LG VX5200 LCD Screen Replacement: étape 5, image 1 de 3 LG VX5200 LCD Screen Replacement: étape 5, image 2 de 3 LG VX5200 LCD Screen Replacement: étape 5, image 3 de 3
    • Insert the opening tool in the seam of the top portion of the flip phone.
    • Gently pry the seam open.
    • Move the opening tool around the perimeter of the seam and gently take the front LCD face plate out.
  6. LG VX5200 LCD Screen Replacement: étape 6, image 1 de 3 LG VX5200 LCD Screen Replacement: étape 6, image 2 de 3 LG VX5200 LCD Screen Replacement: étape 6, image 3 de 3
    • Close the flip phone.
    • Hold the base of the phone and gently remove the faceplate.
    • Place the phone and the faceplate on a clean, flat surface.
  7. LG VX5200 LCD Screen Replacement, LCD Screen: étape 7, image 1 de 2 LG VX5200 LCD Screen Replacement, LCD Screen: étape 7, image 2 de 2
    • Try not to move the thin component wires as they will bend and break very easily.
  8. LG VX5200 LCD Screen Replacement: étape 8, image 1 de 3 LG VX5200 LCD Screen Replacement: étape 8, image 2 de 3 LG VX5200 LCD Screen Replacement: étape 8, image 3 de 3
    • Remove the white stopper from the camera light located above the gold connector.
    • Lift the gold connector up with your finger to detach it.
  9. LG VX5200 LCD Screen Replacement: étape 9, image 1 de 1
    • Gently lift out the speaker with your fingertip.
  10. LG VX5200 LCD Screen Replacement: étape 10, image 1 de 3 LG VX5200 LCD Screen Replacement: étape 10, image 2 de 3 LG VX5200 LCD Screen Replacement: étape 10, image 3 de 3
    Outil utilisé dans cette étape :
    • Gently lift out the square LCD assembly being careful with the attached vibrator wires.
    • Gently remove the vibrator with tweezers.
    • The LCD screen, speaker and vibrator will separate from the phone as a single unit.
  11. LG VX5200 LCD Screen Replacement: étape 11, image 1 de 2 LG VX5200 LCD Screen Replacement: étape 11, image 2 de 2
    • Place phone body and LCD screen on a clean, lint-free surface.
3 autres ont terminé cette réparation.
Douglas Blaalid
Membre depuis le 01/13/10
282 Réputation
8 tutoriels rédigés
Équipe
Cal Poly, Team 4-13, Forte Winter 2010 Membre de l'équipe Cal Poly, Team 4-13, Forte Winter 2010
CPSU-FORTE-W10S4G13
5 membres
15 tutoriels rédigés
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 5
30 derniers jours : 15
Total : 4,023
