Aller au contenu principal
LG WM3050CW Control Panel Replacement
Ce dont vous avez besoin
  1. LG WM3050CW Control Panel Replacement, Safety Precautions: étape 1, image 1 de 2 LG WM3050CW Control Panel Replacement, Safety Precautions: étape 1, image 2 de 2
    • Before you begin your repair, perform the following:
    • Turn off the main water supply
    • Unplug your washer
    • Disconnect all water connections at the rear of your washer
  2. LG WM3050CW Control Panel Replacement, Unfasten the top panel: étape 2, image 1 de 3 LG WM3050CW Control Panel Replacement, Unfasten the top panel: étape 2, image 2 de 3 LG WM3050CW Control Panel Replacement, Unfasten the top panel: étape 2, image 3 de 3
    • Use a Phillips driver to remove the two bottom 16.5 mm-long screws securing the top panel brackets.
  3. LG WM3050CW Control Panel Replacement, Remove the top panel: étape 3, image 1 de 2 LG WM3050CW Control Panel Replacement, Remove the top panel: étape 3, image 2 de 2
    • Slide the top panel 1-2 inches towards the rear of the device to disconnect its clips.
  4. LG WM3050CW Control Panel Replacement: étape 4, image 1 de 2 LG WM3050CW Control Panel Replacement: étape 4, image 2 de 2
    • Tilt the top panel upward to completely disconnect it from the chassis.
    • Remove the top panel.
  5. LG WM3050CW Control Panel Replacement, Remove the detergent drawer: étape 5, image 1 de 2 LG WM3050CW Control Panel Replacement, Remove the detergent drawer: étape 5, image 2 de 2
    • Pull the detergent drawer away from the chassis as far as it will go.
  6. LG WM3050CW Control Panel Replacement: étape 6, image 1 de 3 LG WM3050CW Control Panel Replacement: étape 6, image 2 de 3 LG WM3050CW Control Panel Replacement: étape 6, image 3 de 3
    • Press down on the "Push" button to disengage the clips securing the detergent drawer.
    • Pull the drawer out of its slot on the chassis and remove it.
  7. LG WM3050CW Control Panel Replacement, Disconnect the control panel: étape 7, image 1 de 3 LG WM3050CW Control Panel Replacement, Disconnect the control panel: étape 7, image 2 de 3 LG WM3050CW Control Panel Replacement, Disconnect the control panel: étape 7, image 3 de 3
    • Disconnect the three harness connectors for the control panel.
    • Always grip cables by their connectors and not the wires themselves.
  8. LG WM3050CW Control Panel Replacement, Unfasten the control panel: étape 8, image 1 de 2 LG WM3050CW Control Panel Replacement, Unfasten the control panel: étape 8, image 2 de 2
    • Use a Phillips driver to remove the 16.4 mm-long screw securing the control panel.
  9. LG WM3050CW Control Panel Replacement, Unfasten the detergent dispenser: étape 9, image 1 de 1
    • Use a Phillips driver to remove the two 26.3 mm‑long screws securing the detergent dispenser.
  10. LG WM3050CW Control Panel Replacement, Unclip the control panel: étape 10, image 1 de 3 LG WM3050CW Control Panel Replacement, Unclip the control panel: étape 10, image 2 de 3 LG WM3050CW Control Panel Replacement, Unclip the control panel: étape 10, image 3 de 3
    • Insert a flathead screwdriver between the chassis and the top left corner of the control panel.
    • Twist the screwdriver to release the clips securing the control panel.
    • Repeat this procedure for the remaining clips along the control panel.
  11. LG WM3050CW Control Panel Replacement, Remove the control panel: étape 11, image 1 de 3 LG WM3050CW Control Panel Replacement, Remove the control panel: étape 11, image 2 de 3 LG WM3050CW Control Panel Replacement, Remove the control panel: étape 11, image 3 de 3
    • Lift the control panel upward to completely separate it from the chassis.
    • Pull the control panel away from the chassis, making sure to thread the cables through its slot in the chassis.
    • Remove the control panel.
  12. LG WM3050CW Control Panel Replacement, Unfasten the control panel cover: étape 12, image 1 de 1
    • Flip the control panel over.
    • Use a Phillips driver to remove the seven 16.4 mm-long screws securing the control panel board cover.
  13. LG WM3050CW Control Panel Replacement, Remove the control panel board: étape 13, image 1 de 3 LG WM3050CW Control Panel Replacement, Remove the control panel board: étape 13, image 2 de 3 LG WM3050CW Control Panel Replacement, Remove the control panel board: étape 13, image 3 de 3
    • Pull the control panel board out of its slot and remove it.
Repair didn’t go as planned? Ask our Answers community for help.
Bill Gilbert
Membre depuis le 06/30/22
30 088 Réputation
213 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
136 membres
17 420 tutoriels rédigés
2 commentaires
Thanks for this guide, it looks very easy to follow. I am thinking about replacing my control panel, it works fine except for one annoying problem, the ‘Start’ button is working intermittently. I need to push Start 2 or 3 times before the washer starts. Has anyone seen this? I may just disassemble the washer and see if I can blow out any debris.
Jimjar - Réponse
Hello Jimjar! You can take a shot at blowing stuff out, It is probably the switch on the control panel board that is failing. especially if you don't have trouble with any of the other control buttons. So you might want to start by blowing out the start switch if you have a source of compressed air. While you handle these parts especially blowing air on them, make sure to handle them by the edges, and keep yourself grounded or at least touching something that is grounded frequently. Since the boards are encapsulated (note the honey colored material covering the board) to protect against corrosion, replacing components becomes a chore. So your next step will probably be a replacement control panel board if the cleaning doesn't help. There are services that will repair the board as well; haven't looked into relative cost. You can fix it, and that's a lot better than having to spend for another appliance.
Bill Gilbert -
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 14
Total : 217
