Introduction
Use this guide to replace the stator in your LG WM3050CW Washing Machine.
The stator is part of the direct drive motor. If the motor is broken, it's possible that one or more of the stator coils is burnt out.
Ce dont vous avez besoin
Turn off the main water supply
Unplug your washer
Disconnect all water connections at the rear of your washer
Use a Phillips driver to remove the four 10.7 mm‑long screws securing the rear panel.
Lift the rear panel upward to release its bottom clips.
Pull the rear panel away from the chassis to release the remaining clips.
Use an impact driver to remove the 17 mm nut securing the rotor.
Alternatively, you can use a wrench and a hammer to loosen the nut.
Pull the rotor straight off the stator and drive shaft splines to remove it.
Use a Phillips driver to remove the three 16.6 mm‑long screws securing the top of the motor harness clamp.
Use a 10 mm socket wrench to remove the six 68 mm-long bolts securing the stator.
Pull the stator out of its slot on the drum, and flip it so its rear is facing upward.
Disconnect the two harness connectors attached to the stator.
Use your fingers to unclip the rotor position sensor from the stator.
Pull the sensor away from the stator to completely unclip it.
You're left with the stator.
Repair didn’t go as planned? Ask our Answers community for help.
