Introduction
This guide will show you how to replace the LCD screen on a LG X Power smartphone.
Pièces
Aucune pièce spécifiée.
Insert a plastic opening tool above the AUX jack and slide it around the perimeter to pop the back cover off.
Use the flat end of a spudger to disconnect the front and rear cameras from the motherboard.
Pull the cameras out to remove them.
Carefully peal off the glued vibration motor by using the plastic opening tool.
16 autre(s) ont terminé cette réparation.
4 commentaires
If you are just replacing the screen, this is wrong. This would help if you are replacing with a “screen in frame”
What is the right way for just the screen?
