Aller au contenu principal
LeapFrog LeapPad Ultra XDi USB Charge Port Replacement
Ce dont vous avez besoin
  1. LeapFrog LeapPad Ultra XDi USB Charge Port Replacement, Battery: étape 1, image 1 de 2 LeapFrog LeapPad Ultra XDi USB Charge Port Replacement, Battery: étape 1, image 2 de 2
    • Orient the tablet so it’s laying screen down and the barcode sticker is facing up.
    • Remove the barcode sticker to expose the two screws.
  2. LeapFrog LeapPad Ultra XDi USB Charge Port Replacement: étape 2, image 1 de 2 LeapFrog LeapPad Ultra XDi USB Charge Port Replacement: étape 2, image 2 de 2
    • Remove the two 5.0mm Phillips #0 screws.
  3. LeapFrog LeapPad Ultra XDi USB Charge Port Replacement: étape 3, image 1 de 3 LeapFrog LeapPad Ultra XDi USB Charge Port Replacement: étape 3, image 2 de 3 LeapFrog LeapPad Ultra XDi USB Charge Port Replacement: étape 3, image 3 de 3
    • Using the iFixit opening tool, pry off the purple and white child-proof casing to expose the twelve screws.
  4. LeapFrog LeapPad Ultra XDi USB Charge Port Replacement: étape 4, image 1 de 2 LeapFrog LeapPad Ultra XDi USB Charge Port Replacement: étape 4, image 2 de 2
    • Remove all twelve 7mm Phillips #1 screws located along the edges of the device.
  5. LeapFrog LeapPad Ultra XDi USB Charge Port Replacement: étape 5, image 1 de 2 LeapFrog LeapPad Ultra XDi USB Charge Port Replacement: étape 5, image 2 de 2
    • Remove the purple case, exposing the motherboard and battery.
  6. LeapFrog LeapPad Ultra XDi USB Charge Port Replacement: étape 6, image 1 de 3 LeapFrog LeapPad Ultra XDi USB Charge Port Replacement: étape 6, image 2 de 3 LeapFrog LeapPad Ultra XDi USB Charge Port Replacement: étape 6, image 3 de 3
    • Using your fingers, grab the battery wires and carefully unplug them from the motherboard.
    • Use the Spudger to remove the glued down battery.
  7. LeapFrog LeapPad Ultra XDi USB Charge Port Replacement, Charging Port: étape 7, image 1 de 3 LeapFrog LeapPad Ultra XDi USB Charge Port Replacement, Charging Port: étape 7, image 2 de 3 LeapFrog LeapPad Ultra XDi USB Charge Port Replacement, Charging Port: étape 7, image 3 de 3
    • Locate the three ribbon cables on top of the motherboard.
    • Flip up the locking clip on the ribbon cable connector to release the cable.
    • Disconnect the cables from their connectors.
  8. LeapFrog LeapPad Ultra XDi USB Charge Port Replacement: étape 8, image 1 de 3 LeapFrog LeapPad Ultra XDi USB Charge Port Replacement: étape 8, image 2 de 3 LeapFrog LeapPad Ultra XDi USB Charge Port Replacement: étape 8, image 3 de 3
    • Unscrew the four 5.0 mm Phillips #0 screws securing the motherboard.
  9. LeapFrog LeapPad Ultra XDi USB Charge Port Replacement: étape 9, image 1 de 2 LeapFrog LeapPad Ultra XDi USB Charge Port Replacement: étape 9, image 2 de 2
    • Lift the motherboard up to expose the fourth ribbon cable underneath.
    • Flip up the locking clip to release the cable, and disconnect the cable from the connector.
  10. LeapFrog LeapPad Ultra XDi USB Charge Port Replacement: étape 10, image 1 de 1
    • Locate the charging port on the side of the motherboard.
    • Use a soldering iron to desolder the five metal connections to the motherboard. Replace the USB charge port.
Rachel Baker
Membre depuis le 09/01/19
109 Réputation
1 tutoriel rédigé
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 10
Total : 1,373
