Aller au contenu principal
Left Nintendo Switch NES Controller Charging Rail Replacement
Ce dont vous avez besoin
  1. Left Nintendo Switch NES Controller Charging Rail Replacement, Unscrew the back casing: étape 1, image 1 de 3 Left Nintendo Switch NES Controller Charging Rail Replacement, Unscrew the back casing: étape 1, image 2 de 3 Left Nintendo Switch NES Controller Charging Rail Replacement, Unscrew the back casing: étape 1, image 3 de 3
    • Use a Tri-point #Y00 screwdriver to remove the six 6.0 mm screws securing the back case.
    • Remove the back case from the controller.
  2. Left Nintendo Switch NES Controller Charging Rail Replacement, Unscrew the battery housing: étape 2, image 1 de 3 Left Nintendo Switch NES Controller Charging Rail Replacement, Unscrew the battery housing: étape 2, image 2 de 3 Left Nintendo Switch NES Controller Charging Rail Replacement, Unscrew the battery housing: étape 2, image 3 de 3
    • Use a Phillips #000 to remove three 3.0 mm screws holding the battery and it's housing.
    • Remove the battery housing with the battery from the main board and set it aside.
    • At this point the battery is still attached to the motherboard by a connector so don't pull it off the board.
    • If you're not replacing the battery, you can leave it attached to the board to complete the repair, just be careful when moving them so you don't damage the connection.
  3. Left Nintendo Switch NES Controller Charging Rail Replacement, Pry the ZIF connectors up: étape 3, image 1 de 3 Left Nintendo Switch NES Controller Charging Rail Replacement, Pry the ZIF connectors up: étape 3, image 2 de 3 Left Nintendo Switch NES Controller Charging Rail Replacement, Pry the ZIF connectors up: étape 3, image 3 de 3
    • Use the tip of a spudger or your fingernail to flip up the small locking flaps on the two ZIF Connectors. Then, you can safely pull the cable out.
    • Be sure to pry up on the hinged flap, not the connector socket.
  4. Left Nintendo Switch NES Controller Charging Rail Replacement, Remove the charging rail: étape 4, image 1 de 3 Left Nintendo Switch NES Controller Charging Rail Replacement, Remove the charging rail: étape 4, image 2 de 3 Left Nintendo Switch NES Controller Charging Rail Replacement, Remove the charging rail: étape 4, image 3 de 3
    • Use a Phillips #000 to remove the single 3.0 mm screw holding the charging rail to the back plate.
    • Remove the charging rail.
  5. Left Nintendo Switch NES Controller Charging Rail Replacement, Remove the rail PCB: étape 5, image 1 de 3 Left Nintendo Switch NES Controller Charging Rail Replacement, Remove the rail PCB: étape 5, image 2 de 3 Left Nintendo Switch NES Controller Charging Rail Replacement, Remove the rail PCB: étape 5, image 3 de 3
    • Use a Phillips #000 screwdriver to remove two 3.0mm screws from the rail PCB.
    • Remove the charging rail PCB.
  6. Left Nintendo Switch NES Controller Charging Rail Replacement, Take the SL, SR and Sync buttons out: étape 6, image 1 de 3 Left Nintendo Switch NES Controller Charging Rail Replacement, Take the SL, SR and Sync buttons out: étape 6, image 2 de 3 Left Nintendo Switch NES Controller Charging Rail Replacement, Take the SL, SR and Sync buttons out: étape 6, image 3 de 3
    Outil utilisé dans cette étape :
    J'achète
    • Using tweezers, remove the SL and SR buttons.
    • Do the same for the Sync button between them.
We hope you enjoy your new and improved Charging Rail for your Nintendo Switch NES Controller.
To put the device back together, follow this guide in reverse.
2 autres ont terminé cette réparation.
Dominik Szwec
Membre depuis le 01/14/22
148 Réputation
1 tutoriel rédigé
Équipe
York University, Team M-26, Allen Winter 2023 Membre de l'équipe York University, Team M-26, Allen Winter 2023
YORK-ALLEN-W23SMG26
1 membre
2 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 10
30 derniers jours : 45
Total : 783
