Aller au contenu principal
Lenovo 500e Chromebook 2nd Gen Motherboard Replacement
Ce dont vous avez besoin
  1. Lenovo 500e Chromebook 2nd Gen Motherboard Replacement, Back Panel: étape 1, image 1 de 1
    • Remove nine 6 mm screws from the bottom cover of the laptop using a Phillips #0 screwdriver.
  2. Lenovo 500e Chromebook 2nd Gen Motherboard Replacement: étape 2, image 1 de 2 Lenovo 500e Chromebook 2nd Gen Motherboard Replacement: étape 2, image 2 de 2
    • Remove stylus from the lower left corner of the back panel.
  3. Lenovo 500e Chromebook 2nd Gen Motherboard Replacement: étape 3, image 1 de 2 Lenovo 500e Chromebook 2nd Gen Motherboard Replacement: étape 3, image 2 de 2
    • Go along the edge of the back panel with an iFixit opening tool until it pops loose.
    • Remove the back panel from the laptop.
  4. Lenovo 500e Chromebook 2nd Gen Motherboard Replacement, Battery: étape 4, image 1 de 1
    • Remove the four 4 mm Phillips #00 screws holding the battery in.
  5. Lenovo 500e Chromebook 2nd Gen Motherboard Replacement: étape 5, image 1 de 2 Lenovo 500e Chromebook 2nd Gen Motherboard Replacement: étape 5, image 2 de 2
    • Use the iFixit opening tool to unplug the battery from the motherboard.
    • Potential for device damage: Make sure to be gentle while removing the wire.
  6. Lenovo 500e Chromebook 2nd Gen Motherboard Replacement: étape 6, image 1 de 1
    • Remove the battery from the laptop.
  7. Lenovo 500e Chromebook 2nd Gen Motherboard Replacement, Motherboard: étape 7, image 1 de 2 Lenovo 500e Chromebook 2nd Gen Motherboard Replacement, Motherboard: étape 7, image 2 de 2
    • Remove the three 4 mm screws (six total) from the left and right side brackets using a Phillips #00 screwdriver.
    • Gently remove the metal brackets from the motherboard.
  8. Lenovo 500e Chromebook 2nd Gen Motherboard Replacement: étape 8, image 1 de 2 Lenovo 500e Chromebook 2nd Gen Motherboard Replacement: étape 8, image 2 de 2
    • Remove the nine 4 mm screws from the motherboard using a Phillips #00 screwdriver.
  9. Lenovo 500e Chromebook 2nd Gen Motherboard Replacement: étape 9, image 1 de 2 Lenovo 500e Chromebook 2nd Gen Motherboard Replacement: étape 9, image 2 de 2
    • Gently remove the USB port from the side housing using an iFixit opening tool.
  10. Lenovo 500e Chromebook 2nd Gen Motherboard Replacement: étape 10, image 1 de 2 Lenovo 500e Chromebook 2nd Gen Motherboard Replacement: étape 10, image 2 de 2
    • Gently peel the metal strip away from the metal backing.
  11. Lenovo 500e Chromebook 2nd Gen Motherboard Replacement: étape 11, image 1 de 1
    • Remove the single 3 mm screw that holds the Wi-Fi card in place using a Phillips #00 screwdriver.
  12. Lenovo 500e Chromebook 2nd Gen Motherboard Replacement: étape 12, image 1 de 2 Lenovo 500e Chromebook 2nd Gen Motherboard Replacement: étape 12, image 2 de 2
    • Disconnect the Wi-Fi card from the motherboard using an iFixit opening tool.
  13. Lenovo 500e Chromebook 2nd Gen Motherboard Replacement: étape 13, image 1 de 3 Lenovo 500e Chromebook 2nd Gen Motherboard Replacement: étape 13, image 2 de 3 Lenovo 500e Chromebook 2nd Gen Motherboard Replacement: étape 13, image 3 de 3
    • Using an iFixit opening tool, disconnect the camera cable.
    • Potential for device damage: Be gentle while removing the wire.
  14. Lenovo 500e Chromebook 2nd Gen Motherboard Replacement: étape 14, image 1 de 2 Lenovo 500e Chromebook 2nd Gen Motherboard Replacement: étape 14, image 2 de 2
    • Using an iFixit opening tool, detach the speaker wiring from the motherboard.
    • Set speakers aside for reinstallation.
  15. Lenovo 500e Chromebook 2nd Gen Motherboard Replacement: étape 15, image 1 de 2 Lenovo 500e Chromebook 2nd Gen Motherboard Replacement: étape 15, image 2 de 2
    • Using an iFixit opening tool, detach the track pad connector from the motherboard.
    • Potential for device damage: Be gentle while detaching the connector.
  16. Lenovo 500e Chromebook 2nd Gen Motherboard Replacement: étape 16, image 1 de 3 Lenovo 500e Chromebook 2nd Gen Motherboard Replacement: étape 16, image 2 de 3 Lenovo 500e Chromebook 2nd Gen Motherboard Replacement: étape 16, image 3 de 3
    • Using an iFixit opening tool, detach the keyboard cable from the motherboard.
    • Potential for device damage: Be gentle when detaching the cable.
  17. Lenovo 500e Chromebook 2nd Gen Motherboard Replacement: étape 17, image 1 de 2 Lenovo 500e Chromebook 2nd Gen Motherboard Replacement: étape 17, image 2 de 2
    Outil utilisé dans cette étape :
    J'achète
    • Using tweezers, disconnect the black cable from the motherboard.
    • Potential for device damage: Be gentle while detaching the cable.
  18. Lenovo 500e Chromebook 2nd Gen Motherboard Replacement: étape 18, image 1 de 1
    • Gently remove the motherboard from the laptop.
Nicolas Lidinsky
Membre depuis le 01/09/22
701 Réputation
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 12
30 derniers jours : 48
Total : 733
