Aller au contenu principal
Lenovo 500e Chromebook 2nd Gen Wi-Fi Card Replacement
Ce dont vous avez besoin
  1. Lenovo 500e Chromebook 2nd Gen Wi-Fi Card Replacement, Back Panel: étape 1, image 1 de 1
    • Remove nine 6 mm screws from the bottom cover of the laptop using a Phillips #0 screwdriver.
  2. Lenovo 500e Chromebook 2nd Gen Wi-Fi Card Replacement: étape 2, image 1 de 2 Lenovo 500e Chromebook 2nd Gen Wi-Fi Card Replacement: étape 2, image 2 de 2
    • Remove stylus from the lower left corner of the back panel.
  3. Lenovo 500e Chromebook 2nd Gen Wi-Fi Card Replacement: étape 3, image 1 de 2 Lenovo 500e Chromebook 2nd Gen Wi-Fi Card Replacement: étape 3, image 2 de 2
    • Go along the edge of the back panel with an iFixit opening tool until it pops loose.
    • Remove the back panel from the laptop.
  4. Lenovo 500e Chromebook 2nd Gen Wi-Fi Card Replacement, Battery: étape 4, image 1 de 1
    • Remove the four 4 mm Phillips #00 screws holding the battery in.
  5. Lenovo 500e Chromebook 2nd Gen Wi-Fi Card Replacement: étape 5, image 1 de 2 Lenovo 500e Chromebook 2nd Gen Wi-Fi Card Replacement: étape 5, image 2 de 2
    • Use the iFixit opening tool to unplug the battery from the motherboard.
    • Potential for device damage: Make sure to be gentle while removing the wire.
  6. Lenovo 500e Chromebook 2nd Gen Wi-Fi Card Replacement: étape 6, image 1 de 1
    • Remove the battery from the laptop.
  7. Lenovo 500e Chromebook 2nd Gen Wi-Fi Card Replacement, Wi-Fi Card: étape 7, image 1 de 2 Lenovo 500e Chromebook 2nd Gen Wi-Fi Card Replacement, Wi-Fi Card: étape 7, image 2 de 2
    • Remove the single 2 mm screw from the Wi-Fi card using a Phillips #00 screwdriver.
  8. Lenovo 500e Chromebook 2nd Gen Wi-Fi Card Replacement: étape 8, image 1 de 2 Lenovo 500e Chromebook 2nd Gen Wi-Fi Card Replacement: étape 8, image 2 de 2
    • Detach the Wi-Fi card from the motherboard using an iFixit opening tool.
  9. Lenovo 500e Chromebook 2nd Gen Wi-Fi Card Replacement: étape 9, image 1 de 2 Lenovo 500e Chromebook 2nd Gen Wi-Fi Card Replacement: étape 9, image 2 de 2
    • Using tweezers, disconnect the two wires from the Wi-Fi card.
    • Remove the Wi-Fi card from the laptop.
Nicolas Lidinsky
Membre depuis le 01/09/22
701 Réputation
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 13
30 derniers jours : 47
Total : 780
