Aller au contenu principal
Lenovo B575-1450 Wi-Fi Card Replacement
Ce dont vous avez besoin
  1. Lenovo B575-1450 Wi-Fi Card Replacement, Battery: étape 1, image 1 de 1
    • Turn off the computer.
    • Disconnect the charger from the computer.
    • Flip the computer upside down.
  2. Lenovo B575-1450 Wi-Fi Card Replacement: étape 2, image 1 de 2 Lenovo B575-1450 Wi-Fi Card Replacement: étape 2, image 2 de 2
    • Push the right-hand switch outward into the "unlocked" position.
  3. Lenovo B575-1450 Wi-Fi Card Replacement: étape 3, image 1 de 3 Lenovo B575-1450 Wi-Fi Card Replacement: étape 3, image 2 de 3 Lenovo B575-1450 Wi-Fi Card Replacement: étape 3, image 3 de 3
    • While holding the battery, use your other hand to push the left clip to the left and pull the battery out.
  4. Lenovo B575-1450 Wi-Fi Card Replacement, Back Panel: étape 4, image 1 de 2 Lenovo B575-1450 Wi-Fi Card Replacement, Back Panel: étape 4, image 2 de 2
    • The screws are captive to the back panel so they are not to be removed.
    • Using the Phillips #00 Screwdriver, Loosen the five 5.4 mm screws around the back panel from the laptop.
  5. Lenovo B575-1450 Wi-Fi Card Replacement: étape 5, image 1 de 1
    • Using a plastic opening tool, pry the back panel from the laptop.
  6. Lenovo B575-1450 Wi-Fi Card Replacement: étape 6, image 1 de 1
    • Pull the panel outward from the rest of the laptop. The inside of the laptop will be exposed. From here you can access the CD-ROM drive, hard drive, and Keyboard.
  7. Lenovo B575-1450 Wi-Fi Card Replacement, Wi-Fi Card: étape 7, image 1 de 1
    • Using the plastic opening tool, detach both black and grey cables from the Wi-Fi card.
  8. Lenovo B575-1450 Wi-Fi Card Replacement: étape 8, image 1 de 1
    • Using the Phillips #00 Screwdriver, remove the one 3.4 mm screw from the Wi-Fi card.
  9. Lenovo B575-1450 Wi-Fi Card Replacement: étape 9, image 1 de 1
    • Remove Wi-Fi card from the laptop by pulling it out.
Carlo Calvillo
Membre depuis le 09/26/16
772 Réputation
6 tutoriels rédigés
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 6
30 derniers jours : 32
Total : 1,155
